TS-590 configuration problem
EI7BA
#1 Posted : Thursday, February 23, 2012 5:54:51 PM(UTC)
Groups: Beta Testers, Registered
Hi Dennis.
I have a weird problem when setting up my TS-590 in LOGic9.
It works fine at 38400 baud and higher, but will not work on any Baud rate slower than that.
I run an SPE 1K-FA amp, which listens to the RS232 line between rig and PC for band information.
My problem, is that I need to run the TS-590 at 9600 Baud, as the SPE can't work any faster than that.
It works fine with my FT-5000, using the same setup.
Vy 73
John EI7BA
#2 Posted : Thursday, February 23, 2012 6:58:45 PM(UTC)
That's a strange one. We had a problem early-on with LOGic 9 that it would not support 38400 and above, but that is fixed obviously.
Try using both the legacy and non-legacy driver and see if that makes a difference. Try changing stop bit settings.
EI7BA
#3 Posted : Tuesday, February 28, 2012 9:27:08 AM(UTC)
Hi Dennis.
I still have the error with the TS590. It won't work at a speed slower than 38400 baud.
When I try, it often crashes LOGic. I've attached pics of the error messages.
Vy 73
John EI7BA
#4 Posted : Tuesday, February 28, 2012 9:51:00 AM(UTC)
Ok, which driver are you using? Tell me exactly -- tell me the number in the dropdown list.
Are you using a USB=>RS232 adapter? WHich chipset does it use? (Look in the device manager).
EI7BA
#5 Posted : Tuesday, February 28, 2012 10:14:36 AM(UTC)
It's number 29.. kenwood 950,850, 590, 450 without sp command.. Legacy
It behaves the same with number 30.
EI7BA
#6 Posted : Tuesday, February 28, 2012 10:27:58 AM(UTC)
Ooops! Sorry!.. I forgot the Com port info..
It's a two com port card.. Sunix chipset.
The FT5000, works OK at 4800 baud, with the same cable on the same comport.
EI7BA
#7 Posted : Tuesday, February 28, 2012 10:44:24 AM(UTC)
Problem solved!.. I checked the com port at 9600 baud with the Yaesu,and it worked OK.
I moved the cable back to the Kenwood, and now it is also working at 9600!!
I have changed cables on that port a few times whilst troubleshooting.
I don't know what's going on here, but it would not work below 38400 before.
Sorry for the QRM Dennis, and thanks (again) for your help.
LOGic 9 seems to have few, if any, outstanding issues now. You've done a great job in sorting out
any problems that have arisen since it's release...and in double quick time too.
Thanks again, and sorry for the QRM
Vy 73
John EI7BA
#8 Posted : Wednesday, February 29, 2012 5:05:47 PM(UTC)
No Problem: I'll add Sunix to our blacklist hihi.
Try the new (non-legacy) Kenwood drivers pse. Let me know how they work.
EI7BA
#9 Posted : Thursday, March 1, 2012 4:45:53 AM(UTC)
Hi Dennis.
I'm using the new driver now...No problems so far.
Vy 73
John EI7BA
