Voice Keyer problem
AB3FL
#1 Posted : Thursday, February 23, 2012 10:25:12 AM(UTC)
Hi all,
I am trying to get the voice keyer to work. I created a 11025KHz wav file and set it up in position '1'. I have set up the RTS line of com4 to trigger the PTT. When I click on '1', the PTT activates and the wav file is played through the rig. However, the PTT it never released after the WAV file plays. I am using a rigexpert plus to control the rig(TS-2000) with the latest drivers(FTDI). The build in sound device is a PCM2906 using the standard "USB Audio Device" drive. I am running the demo as I wanted to make sure the voice keyer worked before I bought Logic 9. The rigexpert works properly with MIXW
thanks
Tom
73 de AB3FL
#2 Posted : Thursday, February 23, 2012 11:17:44 AM(UTC)
Ok, sorry, there is a problem. Thanks for telling me. I found the problem and fixed it.
Please unzip the attached file and save the .DLL to c:\program files (x86)\logic\assembly (or it might be in
c:\program files\logic\assembly depending on what version of Windows you have).
Let me know if this fixes it for you.
This fix will be in the production copies next week.
PDADirectSound.zip (9kb) downloaded 2 time(s).
AB3FL
#3 Posted : Thursday, February 23, 2012 11:26:46 AM(UTC)
Wow! Thant was fast. It fixed the problem
thanks
Tom - AB3FL
