Using function keys with Telnet
K7PDW
#1 Posted : Sunday, November 18, 2018 2:20:32 PM(UTC)
DAVE
I'm trying to program the terminal function keys with commands to control dx cluster NC7J. The expression builder keep giving me errors. For example: set/dx/filter Spotterstate=tx or Spotterstate=ok or Spotterstate=nm The expression build said error so I started to delete the command a section at a time and finally got all the way back to set/dx/filter and still got an error. I also tried it with spaces in place of slash. NC7J dx cluster will accept both. Still had errors.
So I decided to try uploading files with various commands and that worked as far a NC7J was concerned but after upload the mouse pointer remained in the busy circle and would not return to the arrow. I had to go back to the computer's mouse settings and apply the mouse pointer settings again.
Anyone have any ideas what I am doing wrong in either of these situations?
Dave,K7PDW
#2 Posted : Sunday, November 18, 2018 4:00:52 PM(UTC)
Here is some examples I use.
Description: sh/d
Expression: "sh/dx/100{CR}"
sh/u
"sh/u{CR}"
"wa4pgm{CR}"
WN4AZY on 11/18/2018(UTC)
K7PDW
#3 Posted : Monday, November 19, 2018 2:47:45 PM(UTC)
DAVE
I'm not having problems with AR-Custer syntax. I can type the commands directly into NC7J from Logic 9's telnet 1 window without problems, but when I try to type the same commands into the terminal function keys Logic 9's expression build says there are syntax errors.
Example: set/dx/filter spottercont=na
Example: set dx filter spottercont=na
When I type these into the telnet window either one works. Type the same thing into the terminal function keys and the expression builder claims the word "filter" is a syntax error.
There seems to be something about the expression builder error checking that doesn't like certain words.
Dave
#4 Posted : Monday, November 19, 2018 4:26:49 PM(UTC)
I logged into NC7J and used the Expression builder for the Terminal Func Keys
"set/dx/filter spottercont=na"
be sure to include the quotes. Verify ok and NC7J seems to accept it.
See if that works??
WN4AZY on 11/19/2018(UTC), K7PDW on 11/20/2018(UTC)
K7PDW
#5 Posted : Tuesday, November 20, 2018 11:14:01 AM(UTC)
DAVE
Thank you. Somewhere I got the idea that the quote marks would also be transmitter to NC7J and quote marks are not part of the AR-Cluster language as far as I know. Once I included the quote marks in the expression builder syntax the AR commands worked as expected.
Thanks again
Dave, K7DPW
