Cannot directly download LoTW QSL's received
K4ZO
#1 Posted : Thursday, November 15, 2018 1:21:36 PM(UTC)
Was thanked: 8 time(s) in 6 post(s)
I am running version 9.1.38. Ever since installing Logic (and with earlier versions) I have been unable to directly download and process LoTW QSLs received from the LoTW site. I can login and download the file from the LoTW site and then process it manually in Logic and it works fine. When trying to download directly using the Logic script I get an error that says the results were not returned in ADIF format and the most likely cause was an incorrect user name or password. The automatic upload of QSO's to LoTW works fine, and it uses the same username/ password and similar script. A manual login and download of the QSL file also uses the same username/ password. A check with the tech support at LoTW provided no guidance or suggested remedy other than it must be my fault. Any suggestions on how this could be corrected or why it is happening would be appreciated. It could be my fault. I have changed the password at LoTW with no difference in response. This continues to be aggravating but I can still use the program with a little extra effort. It is weird though. Thanks for any suggestions.
K4ZO
#2 Posted : Saturday, November 17, 2018 9:37:42 PM(UTC)
Look at the HTML that appears in the browser window of Logic's callbook window. That will explain what is going on. It is quite a bit to dig thru unfortunately. It is usually something about a bad password or expired certificate.
WB2TPS
#3 Posted : Sunday, December 2, 2018 2:40:48 PM(UTC)
Running WIN7 Logic 9.1.1
LOTW error messageand download
"Could not create SSL/TLS secure channel"
I have had this problem for a week
TQSL is up to date
Any help?
Jim
WB2TPS
#4 Posted : Sunday, December 2, 2018 6:38:12 PM(UTC)
Jim,
You will need to upgrade LOGic, recent changes to LoTW.
WN4AZY on 12/4/2018(UTC)
#5 Posted : Tuesday, December 4, 2018 1:42:01 PM(UTC)
Yeah, they changed the security at the ARRL and we had to change LOGic.
