Hi Bill:
Sorry, I haven't run into this one before.
Do you believe that WJST-x and JAlert are factors? If so, why?
I cannot find which feature in LOGic is causing this error. _5BL0R IB9X is a computer-generated name.
Based on the error message, I suspect that it is either the Band Map or the World Map. Please double-check the line number of the error message. I don't have any files that are 1240 lines long in Band Map or World Map. Could you please disable one or the other and see if the error goes away? If I knew what is causing the error, that would be a big help.
What are you doing in LOGic, if anything, when it happens? I suspect it is caused be a spot being received.
