Long error message when running reports
KB9RNO
#1 Posted : Sunday, January 22, 2012 8:21:43 AM(UTC)
I am getting an error when I try to run a DXCC report for certain bands. i.e. 40m DXCC report.
i sent you an email with the error attached, but never heard from you. I found this forum and decided to post here. I will have several postings, as I have several errors coming up after the install and using the software all weekend.
You can recreate the error, I think, if you do this:
click awards
click reports
choose awards from the list
click okay
choose dxcc from list, leave subaward at main
click next
choose 40m from band
leave mode blank
click next
click next
click next
click next
click finish
error then comes up and a very long one, at that!
click okay on error
report window exits and not report
thanks....
#2 Posted : Tuesday, February 21, 2012 10:41:12 AM(UTC)
Ok, this error is being caused by the spot log. Until we get it resolved, pse close Telnet, Webcluster, and anything else feeding the spot log.
Here is an example of the error you get:
Function/Procedure: FRMAWARDS_REPORTS.FINISH
Error#: 11
Message: Function argument value, type, or count is invalid.
Line# in (memory variable): 12
Line# in Function/Procedure FRMAWARDS_REPORT.FINISH: 12
Code: select field_name, descr, non-edited, user, list, field_type,
lotw_ok, eqsl_ok, subaward1, subdescr1,
subaward2,subdescr2 subaward3,subdescr3,subaward4,subdescr4,
subaward5, subdescr5, subaward6, subdescr6, subaward7, subdescr7,
lotw_ok1,lotw_ok2,lotw_ok3,lotw_ok4,lotw_ok5,lotw_ok6,lotw_ok7,
eqsl_ok1,eqsl_ok2,eqsl_ok3,eqsl_ok4,eqsl_ok5,eqsl_ok6,eqsl_ok7 from
logfields where enabled and (trackaward or thisform.show_non_awards)
order by field_name into cursor prompt_award_cursor
And the report generator loops forever.
