LOGIC not "hearing" K3S after update
NS4X
#1 Posted : Monday, October 22, 2018 10:50:32 PM(UTC)
Just updated to 9.1.38. Real time mode is ON. Rig responds to commands from LOGic but LOGic does not read the frequency or mode from rig. Have not changed anything else and communications between rig and LOGic were fine before upgrade. Other programs (WSJT-X, N1MM) are still communicating normally with the rig. Any suggestions appreciated.
Bart, NS4X
#2 Posted : Tuesday, October 23, 2018 6:28:43 PM(UTC)
Hi Bart:
We didn't change anything with the radio interfaces in .38.
Reinstall .37 and see if that indeed still works.
Then reinstall .38 and log some Com port data and post it here:
http://www.hosenose.com/...-Port-Data-Logging.aspx
FWIW, others report that the K3 is still working with .38.
http://www.hosenose.com/...king-with-K3-Radio.aspx
Try with Polling on and off in LOGic. Either should work, but something to try.
I ASSume the K3s is the same as the K3 with respect to interfacing?
NS4X
#3 Posted : Tuesday, October 23, 2018 7:16:25 PM(UTC)
All is working now, but I can't explain why. I just got home from work, turned on the rig and computer and everything is normal! FWIW, I did try rebooting last night with no success. Nevertheless, I appreciate your quick response.
Bart, NS4X
1 user thanked NS4X for this useful post.
WN4AZY on 10/25/2018(UTC)
