The Request was aborted. Cannot create SSL/TLS secure channel error when importing
#1 Posted : Monday, October 15, 2018 10:16:10 AM(UTC)
We are aware of this error and am researching it. Watch here for updates. Hopefully it will go away on it's own.
#2 Posted : Monday, October 15, 2018 12:29:53 PM(UTC)
The ARRL changed the protocol used for their secure connection. A fix to LOGic will be available in a few days.
http://www.arrl.org/news...bsite-security-software
KA1J on 10/15/2018(UTC)
K2WH
#3 Posted : Monday, October 15, 2018 3:31:42 PM(UTC)
Thanks so much Dennis.
Bill
K2WH
ZL4AS
#4 Posted : Monday, October 15, 2018 5:51:24 PM(UTC)
I have just struck this for the first time today.
Restarting LOGic and totally restarting the computer has not helped.
Oh dear, never mind. Good luck with a fix Dennis.
73, Cliff
Cliff Gray ZL4AS
QRZ info
KD0PO
#5 Posted : Monday, October 15, 2018 6:09:30 PM(UTC)
dokxray
thanks Dennis,
I will check back in a few days
Ray
4x1ru
#6 Posted : Tuesday, October 16, 2018 10:01:48 AM(UTC)
Have the same problem. Started about 24 hours ago. I can upload to LOTW with an error message but can't download. Using Windows 7 Pro.
I will also check back in a few days.
Jim 4X1RU
K7PDW
#7 Posted : Tuesday, October 16, 2018 2:10:57 PM(UTC)
DAVE
Running 9.1.37 and having the same problem
K7UA
#8 Posted : Tuesday, October 16, 2018 10:30:49 PM(UTC)
It bit me today too. I can upload ok, but not download. I just installed a renewed certificate today. I thought that was the problem. Will appreciate a fix. Thank you Dennis.
kk4cb
#9 Posted : Wednesday, October 17, 2018 9:51:53 AM(UTC)
Same here. Export is okay.
Import no.
wa8mcd
#10 Posted : Wednesday, October 17, 2018 1:04:07 PM(UTC)
Doesn't look like it going away on it's own. looking for a magic trick :)
K7PDW
#11 Posted : Thursday, October 18, 2018 8:13:15 AM(UTC)
DAVE
Updated my TQSL Tuesday to V2.4.1. Tried to import today (1300 UTC 18OCT2018). Still no joy. Anybody have a clue as what is going on?
#12 Posted : Thursday, October 18, 2018 12:08:59 PM(UTC)
An updated version of LOGic is available. Chick Help/Check for Updates. Install version 9.1.38.
4 users thanked WN4AZY for this useful post.
K8ZM on 10/18/2018(UTC), KA1J on 10/18/2018(UTC), 4x1ru on 10/19/2018(UTC), w2zi on 10/20/2018(UTC)
K8ZT
#13 Posted : Thursday, October 18, 2018 2:10:31 PM(UTC)
aluscre
Installed, working great now. Thanks K8ZT
KA1J
#14 Posted : Thursday, October 18, 2018 9:22:44 PM(UTC)
Thank you, Dennis.
For whatever reason it first downloaded all my past Q's from LOTW but now that it completed that task, it appears to be working faster than it did before they changed their format.
Gary
KA1J
4x1ru
#15 Posted : Friday, October 19, 2018 7:17:13 AM(UTC)
Just installed 9.1.38 and that solved the problem for me.
Thanks again Dennis.
W8JY
#16 Posted : Friday, October 19, 2018 8:04:01 AM(UTC)
The new update cured the problem. Thanks for the speedy service, Dennis
Jess, W8JY
N0AT
#17 Posted : Friday, October 19, 2018 8:53:03 AM(UTC)
9.1.38 cured the problem. But now I am getting Prefix lookup setup failed errors. Entity Framework Database Access Error. Sequence contains no elements.
The info window contains no data. And Progress for DXCC find says nothing found.
K7PDW
#19 Posted : Friday, October 19, 2018 9:06:29 AM(UTC)
DAVE
Thanks Dennis
#18 Posted : Friday, October 19, 2018 9:17:46 AM(UTC)
Does it fail for every lookup? If not, please send me the lookup that causes the error. .38 has the same prefix table as .37, but the exceptions table is new.
Did you update from .37? Try installing .38 again, choosing the option to install the new factory prefix table. This will overwrite any changes you made if any.
K7UA
#20 Posted : Friday, October 19, 2018 10:25:41 PM(UTC)
All fixed. Thank you Dennis.
This page was generated in 0.099 seconds.
