Import LOTW QSLs error
wb9tfh
#1 Posted : Tuesday, October 2, 2018 2:38:50 PM(UTC)
I get this boxed error message when I select "Import directly from Web"
Underlying connection was closed. An unexpected error occurred on send.
Logic 9.1.30, never had this problem before yesterday. I uploaded LOTW after CQWW RTTY on Sunday over 400 Qs. I imported the N1MM .adif file and it was OK. I still get error message. I sent a print screen of error.
Gil WB9TFH
WB9TFH LOTW ERROR.doc (53kb) downloaded 144 time(s).
#2 Posted : Monday, October 8, 2018 12:18:39 PM(UTC)
I, too, am getting an error with LoTW.
I just upgraded tqsl from 2.4 to 2.4.1 and when I try to download from LoTW, I get the following:
Error 1426 'OLE error code 0x80020006: Unknown name. "has occurred in program
IMPORTADIFRECORD.IMPORT, line 33.
If I cancel, LOGic shuts down.
Thanks, 73
Vin
#3 Posted : Monday, October 8, 2018 6:24:12 PM(UTC)
Hi Gil:
Sorry for the delay in my response. I didn't see it until Vin bumped it. It sounds like a connection problem. Is it per chance working now?
Hi Vin:
It looks like you have an old version of one of the .DLLs that LOGic uses to import ADIF. Please download and install or reinstall the 9.1.37 update again. Let me know if that doesn't fix it. It works here.
BTW, I don't think this has anything to do with TQSL.
Tnx for using LOGic.
#4 Posted : Tuesday, October 9, 2018 8:49:01 AM(UTC)
As always, THANK YOU !!!! I installed 9.1.37 and it solved the issue. No errors.
LoTW is up to date BigGrin
Vin 73
WN4AZY on 10/14/2018(UTC)
