Version 37
W7AO
#1 Posted : Sunday, February 19, 2012 10:58:09 PM(UTC)
Version 37 fixed the Operator/operand type mismatch error. Thanks Dennis. The only problem I now see is if I Set Rig to a spot that is a split spot, the rig goes into a split mode as it should. If I then do a SET Rig to a simplex station, VFO A changes to the new freq, but the radio stays in a split mode and VFO B stays on the origional freq. This can be a real OOoops! creator.
Russ, W7AO
