Help for QSL Report printing
#1 Posted : Thursday, July 26, 2018 2:08:05 PM(UTC)
I need to print on the QSL the number of the ARI club where the CALL is registered.
I created a variable field called SEZ. If it is filled with a number, the CALL is an ARI member, otherwise if it is empty, it is not an ARI member.
Example to be printed:
ARI Section: 0101 (first case)
Nothing to print (second case)
The exact filter conditions are:
DXCC = I or DXCC = IS0
and
SEZ = NOT EMPTY
and
QSL_SENT = R
than print
"ARI Section:" + SEZ (value)
if
SEZ = Empy
than
NO PRINT
I tried but I always managed to print:
ARI Section: 0101
or
ARI Section:
The problem that I can not avoid printing the text "ARI Section:" when the SEZ field is empty.
I cannot be able to program the script but this is the mine to try:
The result is Always .T.ARI Section:0101 or .F.ARI Section:0101
(((CALL='IK0PEQ' OR CALL='IK0JFR') AND (DXCC='I' OR DXCC='IS0') AND QSL_SENT='R' AND NOT EMPTY(TAG_VAL("SEZ:", USERFIELDS, "C"))))
Can you help me writing the right commands to put in my qsl report?
Thank you
#2 Posted : Thursday, July 26, 2018 9:04:16 PM(UTC)
Dear Mauro:
Please clarify: Do you want your QSL report to print ONLY QSO's with SEZ? Or do you want to print all QSOs where QSL_SENT="R", but print the label ARI SECTION only when there is something in SEZ?
If the latter, right-click the label in your report, and select PROPERTIES, then PRINT WHEN. In ONLY WHEN THE EXPRESSION IS TRUE, put
"SEZ:"$USERFIELDS
this would work too -- just longer:
If this is a selecct criteria, it looks like it would prevent QSOs without SEZ from printing a card. But it would have no effect on WHAT prints on the report.
If you want, post your report here and I'll take a look. The report file has a .REP and .FPT part. Zip them up and upload.
IK0CHU on 7/27/2018(UTC)
#3 Posted : Friday, July 27, 2018 3:03:34 AM(UTC)
as always your help was very significant.
I added your indication to my report and everything went well.
I am attaching my screenshots and as you can see everything is perfectly successful.
Thank you
