QSL import/export Windows disappear
Đào minh Anh
#1 Posted : Tuesday, July 17, 2018 6:06:34 AM(UTC)
Help. After the ARRL DXCW Contest I attempted to update my log files. I was able to export to eQSL - almost 600 QSOs. When I attempted to import from eQSL, the box disappeared. I can select the import/export boxes, their presence is confirmed on the bottom task bar but when I attempt to open them on my screen I see a phantom shadow moving from the bottom task bar up and to the left but the box never appears on my monitor. I've tried minimizing all windows but the QSL import and export boxes are never visible now. Been working fine for a year with some uploads over 500 but most in the 20 or so range. I'm at a loss. This occurs with all QSO import/export boxes (both eQSL and LoTW)now. Is there any way to getting the boxes back onto the screen?
#2 Posted : Tuesday, July 17, 2018 8:04:21 AM(UTC)
Maybe they got moved off-screen somehow. Try this:
1. Use the Windows CASCADE function. In win 10, right-click the task bar.
2. Use the CASCADE function in LOGic. Under the WINDOWS menu.
3. The file form.ini stores the window positions. Exit and delete it to set window positioning to factory default. It is in the LOGic install folder c:\program files (x86)\LOGic
This page was generated in 0.016 seconds.
