LOGic Forum
LOGic Support
Report Writer
MODIFY REPORT LAYOUT WINDOW PROBLEMS
Posts: 85  Location: Syracuse, Utah Thanks: 23 times Was thanked: 13 time(s) in 12 post(s)
When I open REPORTS, MODIFY REPORT LAYOUT the right edge of the report bands are cut off and I cannot figure out how to make it so I can see the entire width. Changing the window size does not help. Even when the window is several times larger than the band I'm trying to see, the right edge is cut off. I've looked at several .rep file and the problems is the same for all. Example - The Dymo QSL LABEL.REP file only shows 3 inches while the actual label is 3 1/2 inches. The LOG.REP file only shows about 3/4 of an inch wide regardless of the window size. What am I doing wrong?
Dave, K7PDW
Posts: 1  Location: Accokeek, MD
Originally Posted by: K7PDW  When I open REPORTS, MODIFY REPORT LAYOUT the right edge of the report bands are cut off a....
Dave, K7PDW I am having this same issue. Did you figure out a solution? Deanna, K9DID
Posts: 180  Location: Daytona Beach, Florida Thanks: 48 times Was thanked: 67 time(s) in 62 post(s)
Dave, I don't use that particular report but I selected Reports -> Modify Report Layout and selected the Dymo QSL. I've attached a screenshot of what I see. Does your screen look different? 73s, Don File Attachment(s): dymo.jpg (124kb) downloaded 158 time(s).
LOGic Forum
LOGic Support
Report Writer
