DXCC for KH1 etc
N7IP
#1 Posted : Monday, June 11, 2018 3:09:26 PM(UTC)
Dennis, callsigns with prefixes KH1 --> KH6, KP4 etc are being recorded with DXCC = K. KH0, KG4 work fine. Hopefully is isn't due to some change I made in the prefix file!
Bob, N7IP
#2 Posted : Monday, June 11, 2018 3:52:34 PM(UTC)
The factory prefix table logs KH6XX as KH6 and KP4XX as KP4 here ok.
Go to tools/setup/prefix table.
Look for a KH6 record like in the attached screen shot.
Click the binoculars and enter KH6XX for the callsign. The record that is associated with it will be displayed.
What is the factory prefix table not doing for you? Since we integrated the CTY files, most of the callsigns that don't follow the usual prefix scenario are accounted for.
N7IP
#3 Posted : Monday, June 11, 2018 4:12:10 PM(UTC)
Here is the screen shot. You can see DXCC=K.
Bob
N7IP.pdf (589kb) downloaded 127 time(s).
N7IP
#4 Posted : Monday, June 11, 2018 4:23:22 PM(UTC)
Dennis, I can see the error I made. I have the state entries checked as user-supplied. That was done before you changed the prefix table to show state in the spot log. For some reason, Logic brings up the state DXCC. Just unclicking "user-supplied" solved the problem! I'll go thru and do that for all the states. Sorry to trouble you, but but helped me solve the problem.
Bob
