Bugs in Version 9
W7AO
#1 Posted : Wednesday, February 15, 2012 9:36:32 AM(UTC)
1)Every time I do a Set Rig from the spot log, it puts my radio (FT2000) in to split mode even though the station is running simplex.
2) Still no driver for FT5000 Rotor in update 35.
Russ, W7AO
#2 Posted : Wednesday, February 15, 2012 2:31:07 PM(UTC)
Hi Russ:
There have been previous reports of this. Sorry the .35 update didn't fixit.
Does the problem occur when setting the rig from the rig control toolbar or the log form, or JUST the spot log?
Meantime you can use the FT-9000 (legacy) driver. That will probably work -- it is just the old driver from LOGic 8.
I will add the rotor control when the rig driver is fixed.
W7AO
#3 Posted : Wednesday, February 15, 2012 8:12:17 PM(UTC)
I don't normally have the rig control bar showing. I turned it on and no the problem occurs only when setting the rig from the spot log.
73
Russ, W7AO
W7AO
#4 Posted : Wednesday, February 15, 2012 8:20:38 PM(UTC)
Hi Again,
Yes, the legacy FT9000/FT2000/etc driver works great!
Russ, W7AO
