Welcome Guest! To enable all features please
Login
or
Register
Forum
Active Topics
Search
Help
Login
Register
Search
OK
LOGic Forum
Hardware Support
Serial port and level converter support
New Rigs with USB ports ?
2 Pages
1
2
Goto Page...
Options
View
Previous Topic
Next Topic
K2WH
#1
Posted :
Tuesday, May 29, 2018 9:49:49 AM(UTC)
I have a Yaesu FTdx3000 that has a USB port for data input and output, audio and switching.
It also has a serial port but I would like to use the USB port since it is so easy to use.
Are there any plans to include USB support in the future?
Bill
K2WH
Back to top
User Profile
View All Posts by User
View Thanks
Back to top
W5RAE
#2
Posted :
Tuesday, May 29, 2018 10:46:21 AM(UTC)
Bill,
It's already supported. I have an FTDX-3000 and it is interfaced with LOGic9 using the USB enhanced port and works great. My setup is:
rig FT-9000,FT-5000,FT-2000, COM8, 38400 baud, 2 stop bits
Hope this helps,
Ron
W5RAE
Back to top
1 user thanked W5RAE for this useful post.
on 5/29/2018(UTC)
User Profile
View Thanks
K2WH
#3
Posted :
Sunday, June 3, 2018 6:58:26 AM(UTC)
Originally Posted by: W5RAE
Bill,
Hope this helps,
Ron
W5RAE
Back to top
User Profile
View Thanks
K2WH
#4
Posted :
Sunday, June 3, 2018 7:06:02 AM(UTC)
I'm not sure how to use this site in replying, somewhat confusing since I already replied and my reply has not shown up.
Anyway, thanks for your response, but the FTdx3000 is not listed as a supported rig.
Secondly, if I Tools, Setup, Rig, there are numerous tabs. Which one do I select?
Radio IFC or Radio Terminal and what settings do I choose ?
Bill
K2WH
Back to top
User Profile
View Thanks
W5RAE
#5
Posted :
Monday, June 4, 2018 10:48:27 AM(UTC)
Bill,
select Radio IFC, then select: rig FT-9000,FT-5000,FT-2000, your COM port #, select baud rate you have on the 3000, 2 stop bits
Ron
W5RAE
Back to top
on 6/4/2018(UTC)
User Profile
View Thanks
Posted :
Monday, June 4, 2018 12:21:53 PM(UTC)
I'll add the FT-3000 to the list of rigs in the description of that interface.
Back to top
WWW
User Profile
View Thanks
Posted :
Tuesday, June 5, 2018 3:14:15 PM(UTC)
Unfortunately rigs with USB ports do not simplify anything. They save a little money and clutter is all. They are simply built-in USB=>RS232 converters. They are still seen as a regular old Com port by Windows and LOGic. You still have to know the proper baud rate, etc. Not at all like plugging in a mouse or camera. Maybe someday....
Back to top
WWW
User Profile
View Thanks
w0yv
#8
Posted :
Monday, August 27, 2018 8:30:18 PM(UTC)
I have a FT-991a and the USB to USB port connection using ftdx3000/5000/9000 definitions does not work. I have tried on different computers and numerous COM settings and get the same results. Logic does not crash and seems to communicate with the FT-991a when the COM settings are all correct in computer and radio and Logic. Logic displays the radio's frequency 14.250Mhz as .14250. The mode buttons will change the radio modes but then switch back to showing the first button as pressed. I have used other programs (Fldigi and WSJT-X) with the USB to USB connection and it works on a FT991a definition but won't work if using a FT9000 or FT5000 definition. So if you get a chance it would be great if you can figure out the slight differences between the FT991a and FTdx3000 CAT commands and create a fully working FT-991a definition.
Back to top
WWW
User Profile
View Thanks
Posted :
Tuesday, August 28, 2018 9:14:27 AM(UTC)
I looked at the CAT commands and responses for the 991a and they look in the ballpark for the newer Yeasus -- similar to Kenwood:
https://static.dxenginee...es/y/ysu-ft-991a_us.pdf
Please do this for me. Try the legacy interface, #15. Let me know if it works. My notes say it works with that. But probably that is wrong since you tried the FT-5000 on other programs.
Then switch back to the new interface, #52. Turn COM PORT DATA LOGGER on in the General tab. Operate the rig a minute or so, then turn off the data logger. Send me the result. It will be in LOGic's TMP folder, probably c:\program files (x86)\logic\tmp.
I will fix it for you.
Back to top
WWW
User Profile
View Thanks
N2LVI
#10
Posted :
Tuesday, April 2, 2019 10:05:31 PM(UTC)
Was this problem with the FT-991A ever resolved? I'm trying out the demo program, but if it doesn't work with the FT-991A, the LOGic software is not as useful. I have the same problem with the frequency listed as 1/10 of the actual freq (eg, 1.4250 vs 14.250), shows wrong mode, VFO frequency does not get updated in the log form, etc.
Back to top
User Profile
View Thanks
Posted :
Wednesday, April 3, 2019 3:46:53 PM(UTC)
I tried 15 and 52 and neither worked with my 991. I don't have the 991A but they should be the same. I captured the ComportDataLogger file and attached it here.
COM3_Log.txt
(20kb) downloaded
153
time(s).
Back to top
Edit by user
on 4/5/2019(UTC)
User Profile
View Thanks
Posted :
Friday, April 5, 2019 2:12:41 PM(UTC)
Thanks Kyle--that's exactly what I need. I'll look at it.
Back to top
WWW
User Profile
View Thanks
N2LVI
#13
Posted :
Sunday, April 14, 2019 8:47:33 PM(UTC)
Any progress in getting the FT-991/991A working properly? I'm anxious to try this software out. Thanks!
Back to top
User Profile
View Thanks
Posted :
Friday, May 3, 2019 10:11:34 AM(UTC)
Try the new 9.1.41 update. Let me know how it works.
Back to top
WWW
User Profile
View Thanks
Posted :
Friday, May 3, 2019 11:33:59 AM(UTC)
Not working here.
Logic displays the radio's frequency 14.250Mhz as 1.4250 for example.
See attached file.
COM3_Log.txt
(40kb) downloaded
154
time(s).
Back to top
on 7/7/2019(UTC)
User Profile
View Thanks
N2LVI
#16
Posted :
Monday, July 1, 2019 10:30:52 PM(UTC)
Still no support for the FT-991A? The latest version still displays the frequency shifted one decimal place (see WA4PGM's comments).
Back to top
User Profile
View Thanks
Posted :
Sunday, July 7, 2019 2:36:44 PM(UTC)
Thanks for the post. I missed Kyle's post. I'll work on it today. Should be a simple fix (famous last words).
Back to top
WWW
User Profile
View Thanks
Posted :
Monday, July 8, 2019 4:55:53 AM(UTC)
Ok, try it again. Please re-download and install 9.1.41.
Back to top
WWW
User Profile
View Thanks
Posted :
Monday, July 8, 2019 6:26:39 AM(UTC)
9.1.41 downloaded and installed
not working here.
3.542 is displayed as 3.354200
14.250 is 14.425000
21.017 is 21.101700
etc......
Back to top
User Profile
View Thanks
Posted :
Monday, July 8, 2019 2:44:55 PM(UTC)
I forgot to attach COM port logger
COM3_Log.txt
(118kb) downloaded
0
time(s).
Back to top
on 7/8/2019(UTC)
User Profile
View Thanks
2 Pages
1
2
Goto Page...
LOGic Forum
Hardware Support
News and Announcements, forum usage
- Welcome
- Product reviews and stuff for sale
- Forum news and announcements
- Forum usage questions
LOGic Updates
- LOGic 9 Updates
- LOGic enhancements
- Prefix and Awards Tables Discussion & Updates
- LOGic 8 updates
Hardware Support
- Serial port and level converter support
- General computer hardware support
LOGic Support
- FAQ
--- Windows 7 & Vista
--- Radio Contesting
--- Logging QSOs
--- Installation and Upgrading
--- Radio Interfacing
--- Callbook FAQ
--- Spotting FAQ
--- LOGic's Map
- LOGic 9 Installation and Upgrading
- Logging
- Contesting
- Awards Tracking
- Callbooks & LOGic's Callbook Interface
- Radio & Rotor Interfacing Help & Troubleshooting
- Spotting
- User-defined fields
- Form customization
- Report Writer
- Import and Export
- Bulk data changes and database commands
- Installation & Updating
- Error Messages
- Logbook of The World
- eQSL
- All Other
Non-ham Chitchat
- Non-ham Tech
You
cannot
post new topics in this forum.
You
cannot
reply to topics in this forum.
You
cannot
delete your posts in this forum.
You
cannot
edit your posts in this forum.
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Watch this topic
Email this topic
Print this topic
» Normal
Threaded
Powered by YAF 1.9.5.5
YAF © 2003-2011, Yet Another Forum.NET
This page was generated in 0.081 seconds.
