Groups: Administrators, Beta Testers Posts: 3,258  Location: Auburn, GA Thanks: 1138 times Was thanked: 554 time(s) in 464 post(s)
Hi Bob:
Ok, on the speed issue, it takes about 12 seconds here to load LOGic, set the clock to NIST, open several forms, log into VE7CC, and process 100 spots. Unfortunately logging into telnet is a blocking process. In the new 9.1.35 update I lowered the priority of the spot processing so that it won't be as much of a hog when processing a batch of spots. It may help during routine processing of spots.
On the real problem -- DO nesting level exceeded -- I simply cannot reproduce it. I let LOGic run with VE7CC all night and into the next morning, and no problems at all. I have had no other reports of this.
Looking back to your screen shot, I see some errors from IDPPatch. Do you believe this to be related? Do you know what IDPPatch is? Also, I notice that the frequency display of the rig interface is 0. Is this related?
I did fix an error where you will occasionally get an error about IFCREF not found when closing the telnet form. The fix is not in .35, but it will be in the next update. It is a nuisance error -- if you get it, just click Ignore.
