After trying Ver34 Logic Bombs and CLEANS FAILS
N8PS
#1 Posted : Friday, February 10, 2012 12:01:43 AM(UTC)
Logic 9 was operating OK, even after update 0030, but after
trying to update to #34, Logic would not recover.
Clean failed, indicating error 1705, file access denied.
Removed Logic9 and reinstalled - with the same result.
Will not run -- returns multiple errors. Tried CLEAN and
returned multiple errors too numerous to count.
HELP????
Thanks, de Phil - N8PS
#2 Posted : Friday, February 10, 2012 9:54:09 AM(UTC)
Something else has files open and not letting CLEAN remove them.
As I recall from our conversations, you have LOGic networked. Make sure that no other instance of LOGic is accessing the data.
Look in the task manager and kill any processes related to LOGic (or just reboot).
Failing that, try disabling any virus checkers or anything else that might have LOGic's files open.
Thnx & 73,
N8PS
#3 Posted : Friday, February 10, 2012 12:36:18 PM(UTC)
Found nothing LoGic related in the device manager.
No other instances of LoGic running anywhere on network.
Normally LoGic says "No Shut down properly, Do you want to clean?" Not this time. It tries to open and errors.
Tried to 'force' a Clean from RUN in Start menu but get 1705 Error.
Rebooting does not clear the problem.
Somehow I recall that when this happened before when we were on the phone you advised that LoGic was 'looking'
somewhere where it should not be and we entered some command lines that allowed Clean to work. Can't remember.
Turned off virus protection - No change
Removed and reinstalled after a clean boot - Same problem. The program does not initialize or index assumedly
because CLEAN is needed.
Phil
