LOGic Crashes Setting Rig from Spotlog
KC6X
#1 Posted : Thursday, February 22, 2018 1:49:28 PM(UTC)
ARSKC6X
I am running LOGic 9.1.31. When I hit the LOG or SET RIG button in the Spot Log form, after the rig freq/mode is set, LOGic crashes. I am running Windows 7 Pro x64 SP1.
Here are the error messages from the Application Log:
Application: LOGic.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.IOException
at System.IO.Ports.InternalResources.WinIOError(Int32, System.String)
at System.IO.Ports.SerialStream.EndRead(System.IAsyncResult)
at System.IO.Ports.SerialStream.Read(Byte[], Int32, Int32, Int32)
at System.IO.Ports.SerialStream.Read(Byte[], Int32, Int32)
at System.IO.Ports.SerialPort.ReadExisting()
at PDA.ComPort.Library.port_DataReceived(System.Object, System.IO.Ports.SerialDataReceivedEventArgs)
at System.IO.Ports.SerialPort.CatchReceivedEvents(System.Object, System.IO.Ports.SerialDataReceivedEventArgs)
at System.IO.Ports.SerialStream+EventLoopRunner.CallReceiveEvents(System.Object)
at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
Faulting application name: LOGic.exe, version: 9.1.31.0, time stamp: 0x47139f24
Faulting module name: KERNELBASE.dll, version: 6.1.7601.24024, time stamp: 0x5a58e25a
Exception code: 0xe0434352
Fault offset: 0x0000c54f
Faulting process id: 0x2720
Faulting application start time: 0x01d3ac0a28b0e767
Faulting application path: C:\Program Files (x86)\LOGic\LOGic.exe
Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
Report Id: 8aea376f-17fd-11e8-b963-14dae9104c45
The rig settings have not changed for some time. I am running a Kenwood TS-950SDX. The PC interface is a Microham Microkeyer II.
Thanks.
