Need help with an error message and other items
N7TB
#1 Posted : Friday, February 16, 2018 1:53:26 PM(UTC)
There are times in LOGic that I am getting this error message that usually crashes LOGic.
Top window: Program Error, Unknown member IFCREF.
Second window below: Error 1925 unknown member IFCREF has occurred in program.
TELNETHANDLER.IWWCOMMENTS_DATARECEIVED line 8.
Can someone tell me how to fix this error?
Second thing I am finding with the latest release, and I'm using Win7, is that in the Station Form, when I put in my State, Zip, coordinates and grid square and click ok, it asks if I want to redraw the map. I say yes. Next time I am in the Station Form, all those fields are blank.
If it is possible to get NAQCC and CWops membership data downloaded into LOGic, that would be great.
Terry, de N7TB
#2 Posted : Friday, February 16, 2018 2:56:05 PM(UTC)
Hi Terry:
Are you using Telnet? Does it work at all? Which host are you connected to? Telnet 1 or Telnet 2, or both? Are there any other errors before this.
The State and ZIP fields are just optionally used to help calculate your lat/lon. They will be blank when you reenter the form. However, the lat/lon should retain their last value. What is there? 0.00? Are the displayed distances and directions wrong?
For CWOps, check the members only area and see if there is a file there to download.
I'll add NAQCC.
http://naqcc.info/memberlist_complete.php
N7TB
#3 Posted : Friday, February 16, 2018 5:55:32 PM(UTC)
Yes, Telnet 1 is on, but the error message seems to come up randomly. Not sure if there are errors before this, but I will turn them off and see if I get the same issues.
Thanks for the Station Information update. That is good to know.
Regarding CWOps, I am not a member yet, but do participate in their CWT runs. Since I am not a member, I can't get access to their member list.
Thanks for getting the NAQCC members.
73's
Terry
N7TB
#5 Posted : Saturday, February 24, 2018 3:21:01 PM(UTC)
I found my error. It was due to a faulty usb cable that was intermittent.
Terry
