Posts: 28 Location: Israel
Thanks: 3 times Was thanked: 5 time(s) in 5 post(s)
Z6 does appear in the Prefix List and the DX Calculator but LAT/LO seems to be reversed. Z6 still appears as Servia in the Spot File. The Main Log does not know what to do with Z6, leaves a blank.
Anyone else with this problem?
73, Jim 4X1RU
Hi Jim:
Can't find a problem here. Z6 spots show up as Kosovo, logging a Z6 fills in Z6 for DXCC.
Does the INFO form work?
Make sure the new prefix table got installed. If you don't have any changes you care about, try the FACTORY PREFIX TABLE option.
I'll look at the lat/lon reversal.
INFO works. Gives Republic of Kosovo for Z6. SPOT LOG, MAIN LOG no dice.
Jim
I had reinstalled 9.1.30 using FACTORY PREFIX TABLE.
Jim 4X1RU
Shalom Dennis, I've attached a screen snapshot of the Z6 problem. This might be helpful sorting this out. 73, Jim
Problem solved for me.
Z6 was missing in the file "LIST OF VALID VALUES". So I added it under DXCC and that solves my problem. I don't know if that's the proper fix but it solves my problem .... until the next update.
73, Jim
Glad you got it. It should have just added ZS6 in LIST OF VALID VALUES when you installed the .30 update (provided you checkmarked INSTALL NEW LISTS AND USER-DEFINED FIELDS).
