Logic 9.1.30 - Z6 Kosovo
4x1ru
#1 Posted : Sunday, February 4, 2018 3:39:46 AM(UTC)
Z6 does appear in the Prefix List and the DX Calculator but LAT/LO seems to be reversed.
Z6 still appears as Servia in the Spot File.
The Main Log does not know what to do with Z6, leaves a blank.
Anyone else with this problem?
Jim 4X1RU
#2 Posted : Sunday, February 4, 2018 7:37:46 AM(UTC)
Hi Jim:
Can't find a problem here. Z6 spots show up as Kosovo, logging a Z6 fills in Z6 for DXCC.
Does the INFO form work?
Make sure the new prefix table got installed. If you don't have any changes you care about, try the FACTORY PREFIX TABLE option.
I'll look at the lat/lon reversal.
4x1ru
#3 Posted : Sunday, February 4, 2018 9:13:45 AM(UTC)
INFO works. Gives Republic of Kosovo for Z6. SPOT LOG, MAIN LOG no dice.
Jim
4x1ru
#4 Posted : Sunday, February 4, 2018 9:15:54 AM(UTC)
I had reinstalled 9.1.30 using FACTORY PREFIX TABLE.
Jim 4X1RU
4x1ru
#5 Posted : Thursday, February 8, 2018 4:58:15 AM(UTC)
Shalom Dennis,
I've attached a screen snapshot of the Z6 problem. This might be helpful sorting this out.
73, Jim
180208 Kosovo.jpg (735kb) downloaded 117 time(s).
4x1ru
#6 Posted : Friday, February 9, 2018 4:20:30 AM(UTC)
Problem solved for me.
Z6 was missing in the file "LIST OF VALID VALUES". So I added it under DXCC and that solves my problem. I don't know if that's the proper fix but it solves my problem .... until the next update.
Jim
#7 Posted : Friday, February 9, 2018 9:29:23 AM(UTC)
Glad you got it. It should have just added ZS6 in LIST OF VALID VALUES when you installed the .30 update (provided you checkmarked INSTALL NEW LISTS AND USER-DEFINED FIELDS).
4x1ru on 2/9/2018(UTC)
