Reports Other Beam Headings and Gray Line
N3AS
#1 Posted : Wednesday, February 8, 2012 1:06:50 PM(UTC)
Dennis:
I installed Logic 9 on my computer runing Windows 7 Home Premium 64 bit. The Main program is running fine. I was checking to see that the program features were running ok like in previous versions of Logic and discovered 2 additional issues.
When I access the Reports menu: Other and attempt to run a Beam Heading Chart, when I hit the Print button I receive an error message.
Variable "DX" is not found (error no. 12)
I attempted to run the Gray Line report and a similar error appeared when I hit the Print button.
Program Error Variable "DX" is not found. When I hit continue a message indicated no information was found.
I suspect these error messages are related to the earlier post I sent regarding the program not listing my HERE information in the DX Calculator.
Sorry for the two posts but just discovered the additional issues.
Carmen Perfetta N3AS
#2 Posted : Thursday, February 9, 2012 8:38:36 AM(UTC)
Sorry, I forgot all about these reports. The new prefix table no longer has DX and DIRECTION fields -- they are calculated as-needed now.
Here are the new reports. It will be in the next update, but meanwhile pse unzip and put the files in the REPORT folder inside the LOGIC folder.
BEAM HEADING CHART & GrayLine.zip (10kb) downloaded 155 time(s).
