Groups: Administrators, Beta Testers Posts: 3,256  Location: Auburn, GA Thanks: 1134 times Was thanked: 553 time(s) in 463 post(s)
From your screen shot, I can't see what stage the ADIF import is at. Is it just the opening screen? Does the Roxio thing pop up after the ADIF dialog pops up, but before the file selector dialog pops up?
What I am thinking is this: The ADIF import form remembers the last location you imported from. For instance, if you import something from z:\xyxxy, the dialog will automatically point to z:\zyzzy the next time you use ADIF import. So I am guessing that this remembered location got set to your DVD drive somehow. That SHOULDN'T cause the Roxio thing to come up of course, but if they hooked their installer into any reference to the DVD drive, that would explain it.
To reset the remembered location, go into the LOGic install folder. Open PDA.INI in notepad or any text editor. Look for the [Default Directories] section.
Look for an entry under it like this: Select ADIF log file=F:\
If it is pointed to your DVD drive, change it to something else or just delete the whole line. May as well fix any other paths listed.
