Groups: Administrators, Beta Testers Posts: 3,203  Location: Auburn, GA Thanks: 1101 times Was thanked: 530 time(s) in 443 post(s)
Ok, no problem with LoTW here.
My guess is that you have something blocking LOGic.exe from accessing the internet. Try turning off your antivirus/web protection software and see if the problem goes away. If that is it, then there has to be some way to tell it to permit LOGic to access the web.
On the K3 setting freq first then mode, I have not addressed that. It is a function of LOGic, not a particular driver. Typically you get a freq shift when you change mode, so you HAVE to set the mode first.
Anyway, I checked my code and I did move the set-mode-and-freq code to the driver, so I can override the default code for the K3. Thanks for the reminder. Will do it after I get the next report on the .32 update's K3 driver.
