Logic 9 Rotor Selection Problem
W7HPW
#1 Posted : Wednesday, January 25, 2012 9:52:30 PM(UTC)
The buttons for short path and long path on the "Spot Log" will only run rotor 1, even though you have rotor 2 selected in the band table for that band.
The "rotor control head" will run either rotor if you select rotor 1 or 2, but not in "automatic" then it will only run rotor 1.
The rotor driver "PDA LOGic.Rotorifc.HyGain_DCU1" does not work. The HyGain_DCU1 (legacy) drivers are working just fine. Rotors here are Green Heron and microHAM.
Broken!
Mark
W7HPW
PS The same applies when selecting rotor heading from the world map
#2 Posted : Monday, January 30, 2012 10:14:05 PM(UTC)
The error with the new DCU1 interface has been fixed and verified. Try it out -- it sends the direction back to LOGic.
I will have to research rotor selection. Nothing changed from LOGic 8 supposedly.
W7HPW
#3 Posted : Monday, January 30, 2012 10:58:54 PM(UTC)
OK I must be missing something. where do I download the new drivers?
Mark
W7HPW
#4 Posted : Tuesday, January 31, 2012 9:26:41 AM(UTC)
W7HPW
#5 Posted : Tuesday, January 31, 2012 9:42:46 PM(UTC)
The new drivers work fine, from your comments you don't have a fix for the rotor selection problem. And you can’t select a rotor heading by clicking on the map either. For either rotor, although it seems to try, it does turn on the rotor controller but nothing happens.
Mark
W7HPW
W7HPW
#6 Posted : Monday, February 6, 2012 8:58:44 PM(UTC)
OK I found the problem, in the "Log form setup" - "Rig, Rotor, and Terminal" the rotor selection has to be "Use band table", now the spot log "S" and "L" buttons turn the correct rotor depending on the band of the spot. Spots on the Map, however, will only use rotor 1 even if the spot is in a band that is selected to use the 2nd rotor.
Mark
W7HPW
#7 Posted : Tuesday, February 7, 2012 10:59:08 AM(UTC)
Ok, thanks for the update. I couldn't find a problem here.
