Crash, Locks up When in Spot Log, Alerts, Setup
K2WH
#1 Posted : Saturday, January 20, 2018 12:25:33 PM(UTC)
My Logic9 locks up and needs to be reset continuously when in the spot log, alerts, setup.
I entered Bouvet Island then 3Y.
It didn't like that and totally froze the computer and had to do a Ctrl-Alt-Delete multiple times and upon restarting Logic, it had to go through the entire procedure to run the program.
It think I was able to clear the problem it by getting into the alerts, setup and removing the spot entry before the crash.
Any ideas what's going on?
#2 Posted : Sunday, January 21, 2018 8:21:39 AM(UTC)
Does LOGic work if you don't setup a alert?
How did you set it up?
Click the "+" to add a alert.
Use the Wizard and select "3Y-B" under DXCC
Click OK
WN4AZY on 1/21/2018(UTC)
K2WH
#3 Posted : Sunday, January 21, 2018 10:41:29 AM(UTC)
Tnx,
Didn't know how to use the wizard and you explained it perfectly.
I think it is working now.
Bill
K2WH
#4 Posted : Sunday, January 21, 2018 1:40:36 PM(UTC)
Thanks Kyle:
Bill, you shouldn't be able to enter an invalid expression for Alerts. If you can tell me how you did it, I can fix it to prevent future problems. I played around with it and did manage to get an invalid expression entered, but not sure what I did. I'll keep on it.
#5 Posted : Sunday, January 21, 2018 1:41:43 PM(UTC)
Thanks Kyle:
K2WH
#6 Posted : Sunday, January 21, 2018 2:08:09 PM(UTC)
OK, not knowing what the wizard actually did, I did this.
In the boxes "Description" & "select Criteria", I just placed data in there and clicked on OK. Not sure if I clicked on the "+" first or later one after I entered the data.
I did not do anything with the "Wizard" until it was explained to me and now it is functioning nicely.
Suggestion and maybe a simple fix, the Description and Criteria could be subdued (not allow any entries) until info is put in the Wizard ?
Hope this explanation helps.
Regards,
Bill
K2WH
K2WH
#7 Posted : Sunday, January 21, 2018 2:10:53 PM(UTC)
More.........
IOW, it was not apparent to me that I had to use the Wizard first to get info in the Description and Select Criteria fields.
#8 Posted : Sunday, January 21, 2018 3:32:42 PM(UTC)
We want to leave the option to manually enter an expression, as the wizard does not cover every possible scenario.
Pressing {ESC} would bypass some error checking. I fixed it. Thanks for bringing this to my attention!
