Error importing ADI files
#1 Posted : Wednesday, January 10, 2018 6:30:40 PM(UTC)
for the first an Happy New Year and for second i want to inform You that the import ADIF file whith .27 version dont work and stop it with the response you can see in the screenshot attached.
The same file with .25 version, in my laptop, doing a fine job and add in all the qsos into logbook.
Tia
73's IKØCHU Mauro
#2 Posted : Thursday, January 11, 2018 10:17:00 PM(UTC)
Thanks, and happy new year to you!
http://www.hosenose.com/...W-Problem.aspx#post7523
If this doesn't fix it, pse provide an English translation of the error.
#3 Posted : Friday, January 12, 2018 11:28:18 AM(UTC)
tnx for replay.
With .27 version all the adif files used before i had an OLE error as follows in english :
Error 1429 "OLE IDispatch exception code 0 from mscorlib: an item with the same key has already been added ...." has occurred in program ADIFIMP, line 123.
Yes or NO answer the program crashed.
So installed rewriting in downgrade the .25 version on Logic folder and the import work well as before.
Now running .25 to update my log with the last qso.
There are other problems with CQ, ITUZ, CONT and COUNTRY fields which are not filled duriing the import but i have to check the possible cause better before presenting the question.
Thanks for help.
#4 Posted : Friday, January 12, 2018 12:17:01 PM(UTC)
Did you download 9.1.27 again? I updated the error message in the libraries last night. Please download and install again. Then let me know what the error message is. The problem is likely data-related -- a problem that .25 doesn't check for.
