I have QSOs that are logged as USB in LOGic. They come back from the ARRL as SSB, but when I click the AUTOMATUCALLY CHECK IN THESE QSLS button, it does not change the mode -- it stays USB.
Even so, clicking the AUTOMATUCALLY CHECK IN THESE QSLS does not create any new records in LOGic. For that to happen, you have to have some Qs that show up as NOT FOUND IN LOG, and then click the ADD QSOS FOR QSLS NOT FOUND IN LOG. Do you have any QSOs showing up as NOT FOUND IN LOG? If so, something else is not matching up. I don't think the mode is the issue.
Pse post a copy of your LOGic log and the adif file. Zip them please.
As for the OLE error, make sure you have the latest 9.1.27 update.
