FT8 ADIF import issue
N7IP
#1 Posted : Friday, December 22, 2017 1:59:07 PM(UTC)
When I import QSOs from WSJT-X, at times a few QSOs will have zero data except for the call sign. The error occurs when the gridsquare value = 0 from WSJT_X. Attached is an ADI file from WSJT-X and two screen shots showing the error after importing into Logic.
Appreciate the help.
Bob, N7IP
wsjtx_log.adi (4kb) downloaded 146 time(s).
import problem.pdf (8,470kb) downloaded 140 time(s).
#2 Posted : Saturday, December 23, 2017 6:55:28 AM(UTC)
Since upgrading I noticed the same thing. It appears that the ADI file from WSJT-X is correct. From my import The MSK144 QSOs imported but the JT65 imported with no dates, modes, etc... Dennis will have to look into this one.
Happy Holidays!!
Kyle
#3 Posted : Saturday, December 23, 2017 6:23:54 PM(UTC)
It's not a grid square with a value of zero, but a zero-length grid square field -- a field with NO value. I wouldn't say this is correct ADIF, but I'll fix it shortly. I am working on the problem of LoTW adding a leading a leading zero to single-digit CQ and ITU zones, so will fix this too.
Merry Xmas & 73,
K0HKL
#4 Posted : Sunday, December 24, 2017 11:28:53 AM(UTC)
Also the ADIF doesn't import the power field. 9.1.23 worked great but 9.1.24 and 9.1.25 leave the power at 000
Merry Christmas & 73,
Keith K0HKL
#5 Posted : Monday, December 25, 2017 9:06:29 AM(UTC)
Ok, I fixed the problem with the null gridsquare (and other null fields). Get the new 9.1.26 update.
Please help me with the PWR problem. There is no PWR in the ADIF file you posted. I entered 123 as the default power, and it filled in everything it imported with 123 as it should.
K0HKL
#6 Posted : Tuesday, December 26, 2017 10:45:13 AM(UTC)
I added the screen shot as for the problem with ADIF. There are 2 screen shots 1 photos is version 9.1.1.23 and 2 is 9.1.1.26. as you can see the on import in #1 shows 30 for my power and #2 shows 00 this was done with the same import file from another logging program it may not be a big deal but when you import 10 to 30 files at a time at different power it take lots of time to go back change the power from 00 to what ever it maybe. The import all ways worked very good till version 9.1.1.24
Thanks you for the great program.
K0HKL 73, Keith
version 9.1.23.jpg (272kb) downloaded 128 time(s).
version 9.1.26.jpg (169kb) downloaded 130 time(s).
#7 Posted : Wednesday, December 27, 2017 8:45:44 AM(UTC)
Ok, please post the ADIF file in question and I'll fix it. Or just paste a record or two in a message. The ADIF import was totally rewritten in .24 so we can interface to WJST etc., so I want to get this right.
K0HKL
#8 Posted : Wednesday, December 27, 2017 9:23:56 AM(UTC)
Here is 2 files before the import
Thanks you K0HKL Keith
logic.adi (4kb) downloaded 147 time(s).
1 user thanked K0HKL for this useful post.
WN4AZY on 12/28/2017(UTC)
#9 Posted : Thursday, December 28, 2017 6:02:32 PM(UTC)
Thanks. I fixed it. Get 9.1.27.
K0HKL
#10 Posted : Thursday, December 28, 2017 7:45:09 PM(UTC)
Thanks Dennis
What a fast fix work like it did.
Great support.
73, K0HKL Keith
