LOGic Forum
LOGic Support
Spotting
Localhost Telnet Connection
Posts: 3 Location: Alabama
Try to help a friend with LOGic 9 and VE7CC CC User.
We are trying to create a telnet connection in LOGic 9 for a localhost 127.0.0.1:7300 pointed to VE7CC CC User.
Anybody using this type setup?
Jim/KC4HW
It shouldn't be a problem. Just enter the address as per your post. Are you getting errors? Does it work with another Telnet client?
Well I should have tried another client. He does have N1MM+ working on this computer.
I will give this a try and see how it goes. Will let you know how it works out. Thanks!
Jim/KC4HW
OK, I tried N1MM+ and it failed also.
But, I forgot to enable the localhost telnet within VE7CC CC User. Once I did that then all was good! Thanks for your time and 73.
Jim/KC4HW
LOGic Forum
LOGic Support
Spotting
