Contest_id is being truncated in reports
#1 Posted : Sunday, February 5, 2012 7:38:05 AM(UTC)
G'Day Dennis,
I recently changed the codes I use to identify my contest QSOs. I now use the ADIF 2.7 contest codes which are generally longer than those I used before.
The contest_id field is 20 characters long in the LOG.
But, when printed in "multi-QSO" QSL card reports, the contest_id is being truncated to only 10 characters.
I first discovered this in my own QSL card reports, and have now verified that it also happens in the "standard" multi-QSO QSL card reports.
The truncation would seem to be part of the processing to assemble the multiple QSOs for the cards.
Can you shed any light on where the problem might be. Your assistance is greatly appreciated.
#2 Posted : Tuesday, February 21, 2012 10:37:49 AM(UTC)
Sorry I didn't notice this post.
First, make the Operator field in the log 20 characters using tools/misc utilities/change size of log fields. I'm guessing you've already done this.
Then, modify the report and drag the contest_id field wider using the mouse. I hope there is room to fit on the paper.
#3 Posted : Wednesday, February 22, 2012 2:29:14 AM(UTC)
G'Day,
... did that. Increased "operator" field in log structure to 20 chars. Why did I need to do that?
The problem, truncation of contest_id to 10 chars, still occurs in the QSL card reports. See attached "screen" snaps.
contest_id prints OK in general log reports. See attached images.
Snagit.rar (11kb) downloaded 128 time(s).
#4 Posted : Wednesday, February 22, 2012 9:00:11 AM(UTC)
G'Day,
Say it was ten characters before. That is all that the database would accept. If you want to store more, you have to make it bigger. The same reason you can't put a gun in a pencil case.
Did you modify the report and make the display area of Contest ID bigger? (Besides fixing the database, you have the make the report field wider. The two are independent.)
#5 Posted : Wednesday, February 22, 2012 4:20:28 PM(UTC)
... yes, I also changed the report. I tested two types - a log report, and multi QSO QSL cards.
Only the multi QSO QSL card report truncates the contest_id.
Why do I need too change the size of the "operator" field, when the "contest_id" is being truncated. Both are now 20 chars in the Log database structure.
I suspect the probem lies in the extraction of data from the Log by the function in the report "Before Run" panel. That is ...
lblmult(global.report_ref.selectexp, 5) && function supports 2, 3, or 4 QSOs per label
*delete for empty(call2)
* DH 10/11/96
if empty(global.report_ref.selectexp)
global.report_ref.selectexp=".t."
endif
global.report_ref.selectexp = "(" + global.report_ref.selectexp + ")"
... somewhere in there "contest_id", and "contest_idN where N is 1 to 5, are being truncated to 10 characters.
Attached is an image of the latest version of my report. My report is based on the "standard report". The issue also occurs with the "standard report". JARTS-WW-R should be JARTS-WW-RTTY, and DARC-WAEDC should be DARC-WAEDC-RTTY
QSL Card.png (9kb) downloaded 110 time(s).
#6 Posted : Thursday, February 23, 2012 7:49:07 AM(UTC)
Sorry, I said "Operator" but meant "CONTEST_ID".
You are correct -- the lblmult routine is truncating it. I have fixed the code and the changes will be in the next update -- probably posted next week.
#7 Posted : Sunday, February 26, 2012 3:34:35 AM(UTC)
Fantastic.
I appreciate your efforts.
#8 Posted : Wednesday, February 29, 2012 8:26:58 PM(UTC)
This is now fixed in the latest update .038
#9 Posted : Wednesday, February 29, 2012 10:31:50 PM(UTC)
.. thank you.
Installed and tested OK.
