Updater error
#1 Posted : Friday, November 10, 2017 11:26:57 PM(UTC)
Dennis, have gotten this error several times now while trying to run the updater. Have uninstalled/reinstalled a couple of times;
#2 Posted : Tuesday, November 14, 2017 11:06:22 PM(UTC)
Hello, Dennis.....you around?
#3 Posted : Wednesday, November 15, 2017 10:37:35 AM(UTC)
Sorry for the delay.
I have not seen this error.
What version of Windows do you have?
Doing some reading, it appears to be part of DirectX.
Run DXDIAG. Type {WinKey + R} and type DXDIAG. I have version 12 on my Win 10 machine.
D3DCompiler_47.DLL exists in both my c:\windows\system32 and c:\windows\syswow64 folders.
See if this helps:
https://support.microsof...atest-version-of-directx
I could just send you the files from my computer, but I'm afraid there is a lot of associated stuff that needs to go along with it.
#4 Posted : Wednesday, November 15, 2017 2:56:41 PM(UTC)
I'm win7 sp1, and I show at least a half dozen entries in the search box for that particular .dll. I copied it from one of those locations to both windows/system32 and sysWOW64. I also uninstalled and reinstalled the KB update you mentioned, along with my Logic license setup file. Now, I see the initial DOS box that updater starts, but nothing after that. Am I looking at a windows reinstall?
#5 Posted : Wednesday, November 15, 2017 4:56:25 PM(UTC)
This might be a fix (have not idea), read and I hope it helps.
http://www.tomshardware....ler-dll-missing-fix.html
refers to .NET framework after updates.
Good Luck,
Kyle, WA4PGM
WN4AZY on 11/16/2017(UTC), W5GA on 11/17/2017(UTC)
#6 Posted : Thursday, November 16, 2017 10:48:35 PM(UTC)
Thanks Kyle.
BTW, the d3dcompiled_47.dll file is different in my System32 and SYSWOW64 folder.
#7 Posted : Thursday, November 16, 2017 10:59:25 PM(UTC)
Does DXDIAG show anything funny?
#8 Posted : Friday, November 17, 2017 10:34:10 AM(UTC)
DXDIAG showed nothing at all funny. However, the link Kyle put up did fix the problem. I already had that update installed, so I uninstalled/reinstalled it, and now all is well.
Many thanks for the help to both of you!
This page was generated in 0.079 seconds.
