FLdigi window minimizes when clicking on Logic window
WB3ESR
#1 Posted : Sunday, August 20, 2017 11:49:03 AM(UTC)
When using Logic 9 and FLdigi together, everything works as advertised. However a situation occurs that is annoying and cumbersome. When Logic and FLdigi windows are both open on same screen, and I click on a Logic window, the FLdigi window minimizes (if I minimize Logic I find FLdigi was in background). This minimizing presents problems when in middle of QSO. As a note, the same thing happens when using JT65 and Digipan. Is there an adjustment I can make to keep the FLdigi window (JT65 and Digipan) from minimizing? I've explored the internet for answers, but haven't found a solution that I understand!!!
Gil - K3BLN (ex WB3ESR)
#2 Posted : Monday, August 21, 2017 8:27:11 AM(UTC)
Probably your best solution is to use more than one monitor. There are programs that'll keep Fldigi on top but depending upon your screen layout may present a problem when you wanted to use LOGic.
YMMV!
Kyle, WA4PGM
WN4AZY on 8/22/2017(UTC)
#3 Posted : Tuesday, August 22, 2017 7:24:28 AM(UTC)
Is LOGic merely covering FLDigi? I have only one monitor, but it is a little larger than 1080p, and there is more than enough room to put them side-by-side.
Maybe they could add an ALWAYS ON TOP setting to FLDigi.
