Renaming userfield
#1 Posted : Wednesday, August 2, 2017 8:46:09 AM(UTC)
can I rename an userfield name in the archive and save the contents?
I would like change the name "I PROV" into "WAIP".
Need it an external program to access in the archive? Because i cannot find anything in the Logic.
#2 Posted : Thursday, August 3, 2017 3:20:57 PM(UTC)
It is an easy one-step process. Go to tools/setup/log fields. Navigate to I PROV. Click RENAME USER DEFINED FIELD (a button at the bottom of the window). Rename to WAIP.
The usual disclaimer, make a backup first. Just copy the whole LOGic folder.
IK0CHU on 8/3/2017(UTC)
#3 Posted : Thursday, August 3, 2017 7:26:02 PM(UTC)
look this screenshot thanks.
Is there an external program to delete the space as | CQ:15| ITU:28| and delete |LAT:xxxxx|LON:xxxxx| to save record space??
73's Mauro IKØCHU
#4 Posted : Monday, August 7, 2017 7:39:43 PM(UTC)
Sorry for the problem.
I was wrong. You only have to do step 2. I corrected the post. Still, make a backup!
This command in tools/advanced/database commands should remove the extra space. MAKE A BACKUP FIRST!
USE LOG
REPLACE ALL USERFIELDS WITH STRTRAN(USERFIELDS, "| ", "|")
To delete a user-defined field, click DATABASE FILES/MASS CHANGE/REPLACE USER-DEFINED FIELD CONTENTS. The WITH is just an empty string "". This will delete the data and tag. See this video for more on mass change:
https://www.youtube.com/...?v=5d5gyJVFQEs&t=2s
IK0CHU on 8/8/2017(UTC)
