Error in the SpotLog
#1 Posted : Tuesday, July 18, 2017 11:04:10 AM(UTC)
look the screenshot about RDA code in the comment but reporting IOTA value missing. RDA SA-46 as IOTA SA-046.
There is another value RDA TV-25 but that value is not in the IOTA table and no reporting, as right.
I have a RDA table with formatting two letter and two numbers, tha IOTA is two letters and three numbers.
Why is this happening?
Thanks.
#2 Posted : Tuesday, July 18, 2017 10:16:55 PM(UTC)
Was thanked: 528 time(s) in 441 post(s)
Hi Mauro--
LOGic is simply looking for the continent, an optional dash or space, then any number. I fixed it to require 3 digits.
Could you send me the RDA table to put in LOGic? Then I can add that to the spot log too.
#3 Posted : Wednesday, July 19, 2017 3:40:42 AM(UTC)
of course I will send you immediately my RDA table updated on August 2016. I hope i have created it correctly but still it works very well hi
Thank you.
73's IKØCHU Mauro
RDA.dbf (554kb) downloaded 75 time(s).
#4 Posted : Monday, August 7, 2017 8:27:45 PM(UTC)
I fixed IOTA and added RDA spotting. Get the new 9.1.21 update.
IK0CHU on 8/8/2017(UTC)
#5 Posted : Tuesday, August 8, 2017 4:21:30 PM(UTC)
my experience:
Installed V1.21 and add flag into the SPOT? in Logfield award tracking window.
Closing and re-open the SPOTLOG Windows, before every new spot i get the warning as the screenshot "OLE error code 0x80020006: Unknown name."
Click ignore and i can receive the new spot.
If I delete the flag in spot? no error.
Im missing something to get RDA spot?
Thanks.
73's de IKØCHU
WN4AZY on 8/9/2017(UTC)
#6 Posted : Wednesday, August 9, 2017 8:50:44 AM(UTC)
Oops, sorry. My mistake. I can reproduce it and will fix it.
#7 Posted : Thursday, August 10, 2017 11:33:20 AM(UTC)
I fixed it. Pse download and install again. Version is still 9.1.21.
IK0CHU on 8/10/2017(UTC)
K1ESE
#8 Posted : Thursday, August 10, 2017 1:52:09 PM(UTC)
Downloaded and installed version 9.1.21.
If Band Map is running the program keeps showing this error until it locks up and needs to be closed with task manager.
John K1ESE
1 user thanked K1ESE for this useful post.
WN4AZY on 8/11/2017(UTC)
#11 Posted : Thursday, August 10, 2017 5:08:09 PM(UTC)
I thank You for IOTA and RDA right spotting solved.
In the future can I add Others value to spot in SPOTLog Windows only with a flag in spot? or everyone new need your changes in the program?
My thanks for timely support to the logic users.
#12 Posted : Friday, August 11, 2017 3:29:00 PM(UTC)
The Misc field depends on the spot entered in the proper format VE PROV:AB| for example.
Give me an example of what you want to add.
K1ESE
#13 Posted : Friday, August 11, 2017 4:18:41 PM(UTC)
Dennis -
Did you miss my error report above? I'd like to upgrade to 9.1.21.
John K1ESE
#14 Posted : Friday, August 11, 2017 5:18:38 PM(UTC)
Sorry, I did miss your message. Will fix it soon.
#15 Posted : Saturday, August 12, 2017 9:06:40 AM(UTC)
I would not take up your precious time but answer your question.
Obviously I am interested in Italian awards and I can give you many proper format examples:
DAI:AE001|
DLI:I0-001|
DCI:AG001|
DMI:H579|
etc etc ...
I would like to know the technique, if possible, to implement the spots that are not provided by Logic and if all this does not fit in the programming mode.
I really appreciate your interest.
#9 Posted : Sunday, August 13, 2017 9:49:50 AM(UTC)
John K1ESE
Fixed. Pse download and install again.
K1ESE on 8/13/2017(UTC)
#16 Posted : Sunday, August 13, 2017 9:54:53 AM(UTC)
DAI:AE001|
DLI:I0-001|
DCI:AG001|
DMI:H579|
etc etc ...
It requires quite a bit of programming not to mention database structure changes unfortunately.
How would I differentiate say DAI from DCI? Are there no common values between the two? And could DLI not be confused with IOTA in some cases.
I am concerned that since some awards have - and some don't, that people will not be consistent in entering them.
When people spot these, do they typically put for instace DCI AG001 in the comment? That could be workable.
K1ESE
#10 Posted : Sunday, August 13, 2017 10:30:26 AM(UTC)
John K1ESE
Works great. Thanks!
John K1ESE
#17 Posted : Sunday, August 13, 2017 10:33:58 AM(UTC)
im sorry has been my mistake DAI value is really as DAI:AE0001.
Ok I understood perfectly. I did not do a thorough analysis if there might be identical values ​​between any spot but, for my curiosity, I will do it shortly.
If there are similar values ​​they should interfere with each other if both awards spots are active? I'll explain.
If there are two similar values ​​in an ABC format: AA-01 and FGH format : AA-01, if ABC spotting only is activated, there may be problems?
However, you do not worry about my idea, it involves too much work for you and it makes no sense to distract your work that is most useful to the whole community.
I will continue with my archives for the statistics and will pay more attention to the spots by visual level hi hi.
Thank you for the time you have dedicated me.
73 's Mauro IKØCHU
This page was generated in 0.108 seconds.
