Transferring Logic 9 Contest Log into N1MM Logger+ Call History
WB3ESR
#1 Posted : Saturday, June 17, 2017 4:40:10 PM(UTC)
I would like to transfer the contest log for a specific contest from LOGic 9 into the Call History of N1MM Logger+. (For example my 2016 Field Day Log from LOGic 9 into N1MM Logger+ Call History for my 2017 N1MM Field Day Log.) I'm sure it is not a complicated process, but I don't know where to start. Is there anyone out there who can give a step-by-step on how to do this? While I want to do it for Field Day, I would imagine the same process would hold true for any contest. I am using N1MM Logger for first time.
**Gil**
K3BLN/ex-WB3ESR
#2 Posted : Sunday, June 18, 2017 8:45:51 PM(UTC)
Hi Gil.
Start by clicking tools/export in LOGic. Fill out the filter form with the desired Contest ID and the date range. Select BETWEEN and enter both dates.
Can't help you with n1mm, but it should be straightforward.
#4 Posted : Monday, June 19, 2017 7:17:00 AM(UTC)
Was thanked: 77 time(s) in 72 post(s)
I suggest you either go to the on-line N1MM logger documentation http://n1mm.hamdocs.com/...MM+Logger+Documentation
or join the yahoo user group and post you question there. It is not hard and you will enjoy using N1MM for contesting. There are also several Field Day videos on the N1MM website and on YouTube to help you.
CU in FD as KK5W!
WN4AZY on 6/21/2017(UTC)
#3 Posted : Sunday, June 25, 2017 1:48:24 PM(UTC)
Hi Gil.
Maybe for next year?
1. Open N1MM and setup a New log using FD.
2. File>Import>Import ADIF file> "Choose the file exported from LOGic"
4. After import is completed, Tools>Update Call History with Log
5. File>Export>Export Call History
Good Luck!
Kyle, WA4PGM
WN4AZY on 6/26/2017(UTC)
