incorrect mode when spot comes from a skimmer
N7IP
#1 Posted : Saturday, February 11, 2017 8:02:58 PM(UTC)
I've noticed that when a spot from a skimmer is identified as rtty, Logic uses the freq to determine the mode. It would be nice if Logic picked up the mode from the skimmer.
Bob, N7IP
#2 Posted : Sunday, February 12, 2017 7:33:26 PM(UTC)
Hi Bob:
Pse tell me how to receive skimmer spots. Are they on DX Summit? Are they the ones where the posting call ends in #?
N7IP
#3 Posted : Sunday, February 12, 2017 7:47:04 PM(UTC)
I set up my VE7CC client to provide spots from skimmers. Yes, they I think they are identified by the # sign. Here are two examples of the comment field:
cw 18 db 12 wpm cq
rtty 22 db cq
So if you parse for "rtty" you know it is a rtty signal.
Bob
#4 Posted : Sunday, February 12, 2017 10:32:33 PM(UTC)
Thanks -- I'm letting it run now.
It DOES look for RTTY or RYRY anywhere in the COMMENT field of the spot, and if so, treats it as RTTY. Look in the MODE & ACTUALMODE fields. I haven't gotten any skimmer RTTY spots yet, but I see no reason why they would be treated differently than any other spot.
N7IP
#5 Posted : Monday, February 13, 2017 2:19:10 PM(UTC)
I still see the occasional error and wonder if the mode set in the band map over rides what's in the comment field? See the attached PDF.
Bob
spot.pdf (428kb) downloaded 121 time(s).
#6 Posted : Monday, February 13, 2017 6:44:33 PM(UTC)
Are you referring to the hilighted record? It has
cw 10 db 22 wpm ncdxf bcn
in the comment.
In this case LOGic will get the mode from the band table. It only gets DATA modes from the comment field.
It properly determined the mode as RTTY from the spot of IK2ZEC a few lines above.
So I think everything is working as designed. That doesn't mean it can't be improved. For Skimmer spots, I can get the mode from the comment field when it is CW. The formatting looks pretty consistent.
Are there any other skimmer modes I should look for?
N7IP
#7 Posted : Monday, February 13, 2017 8:16:33 PM(UTC)
The change I would suggest is to get the mode from the skimmer, not the band table. This is especially valuable for DATA because a RTTY, PSK31, or bpsk signal could be anywhere (I'm not sure what sig types the skimmers identify besides these--maybe JT65?). The skimmer will always be correct whereas the mode table is only a static guess.
Bob
#8 Posted : Wednesday, February 15, 2017 9:55:39 AM(UTC)
It is getting data modes from the comment in all QSOs now, not just skimmer spots. If you see a case where this is not working let me know. I check for RTTY, RYRY, PSK31, etc. There could be others that I have not covered, and I should add these, not just for skimmer spots.
I agree, for skimmer spots, I can get the mode from the comment in all cases. That would cover the few cases where someone is operating CW in the phone portion of the band.
N7IP
#9 Posted : Wednesday, February 15, 2017 11:34:40 AM(UTC)
Dennis, the spot.pdf file I sent earlier is an example. Here is another example. In the error field, it says "freq not in band table".
Bob
spot2.pdf (437kb) downloaded 98 time(s).
#10 Posted : Sunday, February 19, 2017 11:00:45 AM(UTC)
Ok, something's wrong with the band table then. Attached is a screen shot of my 80M entries.
N7IP
#11 Posted : Sunday, February 19, 2017 12:23:23 PM(UTC)
Yes, there was a gap in the band table. Thanks for pointing it out. But I still think my suggestion in post #7 above would help spotting accuracy. As I understand it, with your 80m band table, there would be no DATA spots, even if the skimmer indicated rtty in the comment field.
As you can see from the attached screen shot, a 20m cw station shows as a DATA mode because the freq falls into the rtty section of my band table.
Bob
spot3.pdf (531kb) downloaded 133 time(s).
#12 Posted : Wednesday, February 22, 2017 9:24:03 AM(UTC)
I agree -- I was working on it but didn't get it completed in time for the last update. It is done now and will be in the next.
BTW, all of the modes set with an award mode of DATA in tools/setup/modes are determined by looking in the comment area of the spot.
