Telnet 1 Went Missing
K2WH
#1 Posted : Monday, February 6, 2017 2:05:55 PM(UTC)
I have been using Telnet 1 for spotting and it is now no where to be found.
I click on the "Forms" drop down list then item "Telnet 1", but the Telnet 1 form never shows up.
Telnet 2 works, as does DXscape and DxSummit but not Telnet 1. Just doesn't show itself, its not hiding behind other forms either.
Need help to correct. Confused
Bill
K2WH
#2 Posted : Monday, February 6, 2017 10:20:09 PM(UTC)
Click on the Window menu in LOGic. Does Telnet 1 show? If so, click on where it says Telnet 1. If it is offscreen, it will be moved so that a corner is visible.
Also, you can try CASCADE. Be forewarned, this will rearrange ALL windows.
