Needed spot not showing up
N7IP
#1 Posted : Sunday, February 5, 2017 7:20:14 PM(UTC)
Dennis, in the PDF logic1 you can see that the TL8 is a needed contact on 80m but is not showing as needed. On the PDF logic2 you can see that I have the band table set correctly and "QSL has been received" is checked. Any idea why the spot is not showing as needed?
Bob, N7IP
logic1.pdf (492kb) downloaded 116 time(s).
logic2.pdf (439kb) downloaded 101 time(s).
#2 Posted : Monday, February 6, 2017 9:43:21 AM(UTC)
Ok, the first thing to do is Filter in the log form and look for Band=80M and DXCC=TL. Make sure it really is needed.
Also, please make the VALUE, AWARD, SUBAWARD, BAND, and MODE field visible in the spot log. That way we can see of the spot status agrees with the little Progress window.
N7IP
#3 Posted : Monday, February 6, 2017 11:20:13 AM(UTC)
Dennis, yes the TL is needed according to the log. Here is a view of the expanded spot log. Same TL station but different band. Same problem.
Thanks, Bob
logic3.pdf (476kb) downloaded 104 time(s).
#4 Posted : Monday, February 6, 2017 1:39:39 PM(UTC)
Thanks for the pictures.
Sorry, I forgot to mention the most obvious fix. Click Awards/Update awards progress info. If you logged a TL on 80 CW, then deleted it or changed the band or mode after saving, it isn't going to automatically go back and retally everything (if it did, it would have to read the entire log, which takes too long). Update Awards Progress Info does just that -- wipes out all of your progress, reads the entire log, and retallies everything.
If that doesn't do it, I can log in and take a look. Or zip up your entire LOGic folder and send it to me so I can run it here.
N7IP
#5 Posted : Friday, February 10, 2017 6:27:08 PM(UTC)
I had already updated awards progress. I just sent you a Dropbox link to the Logic folder. Also, it appears that the only spots that are actually shown as needed are DATA mode spots.
Bob, N7IP
#6 Posted : Sunday, February 12, 2017 7:25:14 PM(UTC)
Downloading it now. Will get back to you.
#7 Posted : Wednesday, February 22, 2017 11:07:14 AM(UTC)
Found it! See the attached. (Spotting is turned off for CW in tools/setup/modes).
Thanks & 73,
