Using MixW with Logic9
LA1XJA
#1 Posted : Tuesday, January 31, 2012 9:07:40 AM(UTC)
wilford
Hi!
I’m getting these errors when starting Logic already running MixW. The normal error is that the comport is already in use. That's ok. The MixW is hooked on.
Error 1429 "OLE IDispatch exception code 0 from MSComm:
Operation valid only when the port is open.." has occurred in
program
LOGICAPP.ICOM_COMM.FLUSHRX, line 8.
Attempt to continue?
program
LOGICAPP.ICOM_COMM.SEND_BINARY, line 19.
There are several error messages, saying exactly the same, popping up.
#2 Posted : Tuesday, January 31, 2012 9:30:07 AM(UTC)
Ok, sounds like you have LOGic an MixW using the same COM port. You can't do that.
Does MixW support OmniRig? If so, then you could access the same rig with LOGic and MixW.
Dennis WN4aZY
