Telnet scripot issue
N7IP
#1 Posted : Saturday, December 31, 2016 12:46:34 PM(UTC)
I have a script that includes looking for HELLO > prompt and waiting 5 seconds to send the response "show/dx/100". It doesn't work. As you can see below, logic doesn't recognize the "HELLO". Here is the exchange by telent:
Welcome to CC User
*** Connected to: CC User
Please enter your call:
login:
N7IP
DX de KC8QDQ: 18115.0 CT1JOP + 1737Z
N7IP de AE5E >
Hello >
DX de PY2PAL: 28450.0 PY2BMX CQ DXS TEST YAGI 2 ELEMENTOS 5 1736Z
DX de UR4GA: 7139.0 S509PMC tnx QSO 1736Z
LOGic> Waited for HELLO > to be sent by host, but it was not.
LOGic> Check Setup.
Any help fixing this would be greatly appreciated. Thanks,
Bob, N7IP
#2 Posted : Tuesday, January 3, 2017 4:04:16 PM(UTC)
Hi Bob:
Please post the address of this host, and I'll fix you up.
Also, get the 9.1.7 update if you don't have it already. There was a problem where the prompt-response would fail if the host sent additional info after the prompt. This has been fixed. Or so I thought. Maybe I need to extend the look-ahead buffer even more than I did.
Anyway, send me the address.
N7IP
#3 Posted : Tuesday, January 3, 2017 4:54:03 PM(UTC)
Dennis, I use my own cluster client that is connected to VE7CC at dxc.ve7cc.net.
However the script I posted used the AE5E cluster at dxspots.com 204.221.76.52.
Bob
#4 Posted : Wednesday, January 4, 2017 10:21:42 AM(UTC)
Ok, on 204.221.76.52 I am not seeing a HELLO > prompt. I am seeing CCC >. I did not have this in my database. Click + to add a new host record.
Attached is the proper setup for this host. The same setup works for dxc.ve7cc.net. There is already a record in LOGic for this -- just add the CCC > line.
