9.1.5 Telnet Host Test errors
#1 Posted : Monday, November 14, 2016 8:59:23 AM(UTC)
I was running a test on the telnet host to find which ones are good or bad. When one tested good a pop-up error would come up saying "Variable 'NEWGOOD' is not found" I clicked "Ignore" and the test resumed until about 25% then LOGic crashed. Each time I try to test the host LOGic crashes.
Kyle, WA4PGM
#2 Posted : Monday, November 14, 2016 10:28:57 AM(UTC)
Kyle,
You got farther than me. I got the same error "Variable 'NEWGOOD' is not found" I clicked "Ignore" and the test resumed until about 21% then LOGic crashed.
Vin
#3 Posted : Tuesday, November 15, 2016 9:48:11 AM(UTC)
I can't get the error here.
Attached is the scrubbed list. I am in the process of updating the auto-login, but here is what I have so far. Unzip into the DATA folder inside the LOGic install folder. This will WIPE OUT any hosts you have entered!!!
TELNET.zip (9kb) downloaded 109 time(s).
#4 Posted : Tuesday, November 15, 2016 11:40:46 AM(UTC)
Same results with pop-up errors and LOGic crashes at 20.6%
#5 Posted : Tuesday, November 15, 2016 12:38:44 PM(UTC)
Dennis, I've had no (recent) problems with Telnet. Your updated list is missing my regular choice (DXC.N4ZKF.COM).
It's the local CC-CLUSTER telnet port that happens to be here in Daytona Beach.
73s, Don
PS: I've saved my copies of the three files in case your next update replaces those files. (grin)
WN4AZY on 11/25/2016(UTC)
#6 Posted : Friday, November 25, 2016 7:04:06 AM(UTC)
Thanks, I added DXC.N4ZKF.COM to mine.
#7 Posted : Saturday, December 31, 2016 1:12:18 PM(UTC)
I installed LOGic 9.1.7 and ran Telnet SETUP > TEST to see which nodes are still active.
Is it possible that so many nodes are no longer active and "not found"?
Vin
Hosts Tried: 291
Hosts found: 65
Hosts not found: 226
Hosts tested good: 74
Hosts newly tested good: 0
Hosts not tested good: 217
#8 Posted : Saturday, December 31, 2016 5:01:16 PM(UTC)
LOGic 9.1.7
when I run a test I keep getting a Pop-up error "Variable NEWGOOD" is not found."
63 tested
59 Good
59 pop-up errors
#9 Posted : Saturday, December 31, 2016 5:21:16 PM(UTC)
My guess many of the nodes have expired or change of address. I use only one(dxc.w4ml.net) or two(w3lpl) and never had a need for most of them.
WN4AZY on 1/3/2017(UTC)
#10 Posted : Tuesday, January 3, 2017 3:53:07 PM(UTC)
Thanks, I was able to reproduce it here and fixed it.
This utility is mostly for our inhouse use. I have a scrubbed list of hosts now, and am in the process of going thru and updating the auto-login.
Stay tuned!
wa4pgm on 1/11/2017(UTC)
#11 Posted : Wednesday, January 11, 2017 7:45:55 PM(UTC)
Thanks!!
No pop-up errors :)
ZL2ARN-10 ZL2ARN.ATH.CX:7300 found
Done!
Hosts tried: 58
Hosts found: 58
Hosts not found: 0
Hosts tested good: 58
Hosts newly tested good: 58
Hosts not tested good: 0
#12 Posted : Thursday, January 12, 2017 8:24:22 PM(UTC)
Do we need to download and install telnet.zip to 9.1.8 or is it part of the 9.1.8 install?
#13 Posted : Friday, January 13, 2017 7:24:26 AM(UTC)
No Telnet works well in 9.1.8 already.
WN4AZY on 1/14/2017(UTC)
