Returned results are not ADIF error
K7PDW
#1 Posted : Saturday, November 5, 2016 12:20:38 PM(UTC)
DAVE
This started when I moved to a new computer (WIN 10 os). No problem with previous WIN 10 computer
When I try to import from LOTW I get this error "Returned results are not ADIF"
The logicerr.txt file is what comes out instead of the import information from LOTW.
I checked my TQSL and it looks good compared to the one on the old computer.
I ran LOGic 9 import with TQSL in diagnostic mode. The TQSL diagnostic dump file is tqsldiag.log also a text file.
Both files are attached.
logicerr.txt (6kb) downloaded 118 time(s).
tqsldiag_log.txt (6kb) downloaded 134 time(s).
#2 Posted : Tuesday, November 8, 2016 9:47:41 AM(UTC)
Here is the problem portion of the logicerr.txt file:
You must have been issued a certificate before you can log on to the LoTW site.
Try logging in manually and downloading your QSLs. You should get the same error. Contact ARRL if you need help resolving certificate issues. We may be able to help you, but it isn't the sort of thing you have to do very often....
K7PDW
#3 Posted : Wednesday, November 16, 2016 2:43:20 PM(UTC)
DAVE
Cannot find the link on LoTW for downloading QSLs. Please send it.
Dave
#4 Posted : Wednesday, November 16, 2016 8:54:42 PM(UTC)
I think this is what you're looking for:
Login to LoTW
Your QSOs>Download Report
73 Kyle
K7PDW on 11/17/2016(UTC)
K7PDW
#5 Posted : Thursday, November 17, 2016 12:59:01 PM(UTC)
DAVE
How do I wipe out the password file that LOGic 9 created (was saved when I did the initial set up) and make it so LOGic asks for the password each time I export or import. Right now my LOGic asks for the password when I export but does not ask when I import. I think this might be the source of my trouble.
K7PDW
#7 Posted : Friday, November 18, 2016 11:28:13 AM(UTC)
DAVE
Was able to download the report to the desktop then import it to LOGIC successfully. At least now I can keep my log updated. Thanks for getting me there.
#6 Posted : Friday, November 18, 2016 1:52:56 PM(UTC)
You can enter the password any time you like in the Password and Verify fields. If you don't enter it again in VERIFY, it will ask every time if I recall correctly.
K7PDW
#8 Posted : Friday, November 18, 2016 7:57:33 PM(UTC)
DAVE
Tried clearing the call sign and password from the export window, but LOGIC still completed the process and did not ask for password at all. Cleared the call sign and password from the import window, but the behavior did not change. Somehow it is still finding the call sign and password.
#9 Posted : Saturday, November 19, 2016 9:39:44 PM(UTC)
From your email:
I've not been able to import QSL confirmations from LOTW. I can download the file from LOTW to my desktop then import to LOGIC without a hitch. Just cannot do it directly from the web. You suggested that I check my TQSL when I posted the problem on the forum and my TQSL works. I can export from LOGIC to LOTW but import directly from the web gives me a password error. Rather then roll back the revision I was wondering if there was a way to delete the file where LOGIC stores the password and start over. If it is in a file where I can edit a line or something along those lines I can do that. I have already tried to enter a new password in LOGIC and update it on LOTW to match and still the problem persisted.
When I export to LOTW it asks for my password but when I try to import directly from the web it does not ask then gives me the following error. "Returned results are not ADIF. Possible reasons include bad user/password"
You can reinstall 9.1.4 but I doubt it is a LOGic issue. It is easy enough to do, and easy to go back to 9.1.5 if it behaves as I suspect.
LOGic isn't going to ask for the password. You have to enter it in the password box. Look at the results in the white window. It is a bit to read thru, but you will find the error in there. If you don't put anything in the LoTW Web Password field, it will say "Username/password incorrect" about 10% up from the bottom.
I can't remember where I got the password. The web site says it is not the one that comes on the postcard. I think I clicked FORGOT PASSWORD and they emailed it to me. It IS the same one that will log you into the LoTW site.
LoTW Web User (callsign) must be filled in also of course.
It is possible that there is some other problem than incorrect user/password. Read thru the HTML to determine the reason.
K7PDW
#10 Posted : Sunday, November 20, 2016 8:07:39 PM(UTC)
DAVE
The problem seems to be fixed. Not sure what happened. I reinstalled TQSL then loaded my TQSL certificate from the file I had saved when I got the certificate from ARRL. Then I closed TQSL and opened Logic and deleted the password from the Export window and continued the export process. As expected it failed. I then closed Logic and rebooted my computer. I opened Logic and went to the Export window, put in the password and verified it. Both export and import worked. Hopefully it will continue to do so.
I'm not sure what exactly did the trick from all the things I tried, but your suggestions and help are appreciated.
Thank you.
1 user thanked K7PDW for this useful post.
WN4AZY on 11/20/2016(UTC)
