Posts: 12  Location: Velserbroek the Netherlands
Anyone also have problems with LOTW import & export? I have changed nothing but it does'nt work anymore! Running windows7 & logic 9.1.1 73 Theo PA1CW WWW.PA1CW.COM
Posts: 465 Location: Missouri
Thanks: 98 times Was thanked: 157 time(s) in 139 post(s)
Theo, the latest version is 9.1.2, so you might give that a try. I'm running it on a W7 machine, and it's flawless. 73 Doug W5GA 73 Doug W5GA
LoTW did not return ADIF to LOGic. Read thru the HTML dump and it will probably give you more info. Could be a bad user and password, or maybe they are down for maintenance or something.
Dennis when I asked a new LOTW password all import is going OK but..... After a few hours logic will not import. When I go directly to the LOTW website all is going well with this password. Btw exporting my log gives no problem.
When I use my other logging software hrd there is no problem with lotw import
What is changed in Logic 9?
Groups: Administrators, Registered, Beta Testers Posts: 396  Location: Farmville, VA Thanks: 40 times Was thanked: 241 time(s) in 207 post(s)
I am running Version 9.1.3 and just imported from LoTW with no issues.
Quote:What is changed in Logic 9? LoTW itself has changed a lot -- for the better. The TrustedQSL program is quite different. It uploads directly instead of going thru LOGic. Download hasn't changed. Please send me the HTML that is returned when you try to download. Copy and paste into a post here. Without that there isn't much I can do to help. Tnx & 73, Dennis WN4AZY
Ok, it says your user and password is correct.
Reenter your LOTW WEB PASSWORD and VERIFY again. Case matters, I think.
Dennis, you had it right. Problem solved.
73 Theo PA1CW
