LOTW import & export
PA1CW
#1 Posted : Friday, September 23, 2016 3:24:49 PM(UTC)
ptkoning
Anyone also have problems with LOTW import & export?
I have changed nothing but it does'nt work anymore!
Running windows7 & logic 9.1.1
73 Theo PA1CW
WWW.PA1CW.COM
LOGIC9.txt (6kb) downloaded 88 time(s).
#2 Posted : Friday, September 23, 2016 7:01:58 PM(UTC)
Theo, the latest version is 9.1.2, so you might give that a try. I'm running it on a W7 machine, and it's flawless.
#3 Posted : Sunday, September 25, 2016 4:42:55 PM(UTC)
LoTW did not return ADIF to LOGic. Read thru the HTML dump and it will probably give you more info. Could be a bad user and password, or maybe they are down for maintenance or something.
PA1CW
#4 Posted : Wednesday, September 28, 2016 1:58:12 PM(UTC)
ptkoning
Dennis when I asked a new LOTW password all import is going OK but.....
After a few hours logic will not import.
When I go directly to the LOTW website all is going well with this password.
Btw exporting my log gives no problem.
When I use my other logging software hrd there is no problem with lotw import
What is changed in Logic 9?
#5 Posted : Thursday, September 29, 2016 7:02:13 AM(UTC)
Was thanked: 241 time(s) in 207 post(s)
I am running Version 9.1.3 and just imported from LoTW with no issues.
#6 Posted : Thursday, September 29, 2016 7:48:15 AM(UTC)
LoTW itself has changed a lot -- for the better. The TrustedQSL program is quite different. It uploads directly instead of going thru LOGic. Download hasn't changed.
Please send me the HTML that is returned when you try to download. Copy and paste into a post here. Without that there isn't much I can do to help.
#7 Posted : Thursday, September 29, 2016 12:15:57 PM(UTC)
Ok, it says your user and password is correct.
Reenter your LOTW WEB PASSWORD and VERIFY again. Case matters, I think.
PA1CW
#8 Posted : Monday, October 3, 2016 10:41:57 AM(UTC)
ptkoning
Dennis, you had it right.
Problem solved.
73 Theo PA1CW
