Telnet
#1 Posted : Monday, September 26, 2016 6:42:31 PM(UTC)
Since installing 9.1.3, I've received many error messages when using telnet.
I have it setup so that LOGic automatically connects to k1eu.dynip.com on start up. Been using it like this since 8.version 8.x.
When I open LOGic, and I don't see a telnet connection established, I hit "CON" in telnet 1 and I get this error message:
1429 OLE IDispatch exception code 0 from System: cannot access a disposed object.
Object name: 'System.Net.Sockets.Socket'...
Cannot Access a disposed object.
Only option is to hit OK.
Doesn't matter which node I try, I get the same error message.
If I close telnet 1 by hitting the "X" in the top right corner, I get the following error message:
Only option is: Cancel/Ignore/Help
Ignore closes the error message window and I can open another Telnet 1 window.
Cancel shuts Logic down completely.
I re-installed 9.1.3 and tried another node and telnet 2 and get the same results.
Any idea what is going on?
Vin
Update: Now, I can't connect to any node with either telnet 1 or 2. Blushing
#2 Posted : Thursday, September 29, 2016 10:29:19 AM(UTC)
That error
happens when the host disconnects. I fixed it, and am attaching the fix to this post.
However, I CANNOT connect to k1eu.dynip.com, PERIOD. Not with LOGic 1.3, 1.2, or with PuTTY. I don't get an error or anything -- it just looks like the host is disconnecting from any connect it receives.
Try these hosts:
k4uga.tsars.uga.edu:7300
dxc.w1nr.net
db0hgw.dyndns.org:4111
LOGicUpdate_9.1.3.exe (40,656kb) downloaded 120 time(s).
#3 Posted : Thursday, September 29, 2016 10:58:15 AM(UTC)
The fix seems to have worked for any telnet node outside the 1 call area. This is so odd.
I'll stay logged in and let you know how it goes later today.
Vin
#4 Posted : Thursday, September 29, 2016 11:11:52 AM(UTC)
Does dxc.w1nr.net not work for you?
This works here too:
DXUSA.NET:7300
To test whether it is 1.3 or not, so as not to keep having to reinstall 1.2, use the telnet client built into Windows. Run a DOS command prompt. Type TELNET
type:
open [address]
Use a space instead of a colon for the port:
open DXUSA.NET 7300
#5 Posted : Thursday, September 29, 2016 12:29:05 PM(UTC)
Yes, dxc.w1nr.net works going through telnet 1 or 2 in LOGic9.
Vin
WN4AZY on 9/29/2016(UTC)
#6 Posted : Thursday, September 29, 2016 12:45:43 PM(UTC)
I downloaded 9.1.3 again and telnet is working without the errors. I do notice quite a few of the nodes listed are no longer valid. I am testing each node now and will send the updated list once completed.
#8 Posted : Thursday, September 29, 2016 9:59:50 PM(UTC)
Thanks, but there is an automatic thing to do that. I'm running it here and going thru and fixing login.
FYI, what I am talking about: Click on SETUP, then the TEST tab.
#9 Posted : Friday, September 30, 2016 6:23:43 AM(UTC)
I saw the TEST tab and used it to run the check. Thanks!
WN4AZY on 9/30/2016(UTC)
#10 Posted : Friday, September 30, 2016 8:16:33 AM(UTC)
It is giving some false OKs. I added the new telnet socket to it and it seems to be working now. I will run it a few times over the next few days in case some hosts are temporarily down. Then I will delete the bad ones (there's a button for that).
#11 Posted : Friday, September 30, 2016 2:44:55 PM(UTC)
I contacted the node owner and he told me the node crashed. He reset it remotely and now it's up and running.
Vin
WN4AZY on 10/2/2016(UTC)
