LOGic Forum
LOGic Support
Contesting
Attempt to print contest report SCORE_CONTEST error
Posts: 50  Location: Manassas, Va Thanks: 1 times Was thanked: 10 time(s) in 9 post(s)
I was testing out the 9.1.2 version and encountered the following error when attempting to print a contest report:
RunPRG: AN error occured in
Error#: 1773 Message:Class definition SCORE_CONTEST is not found. Line#: in (memory variable): 19 Code: Alias: LOG
I got this same error for the two contests I tried to print; ARRL 10 METER and the va qso party (in & out of state).
Is there something different that needs to be done to print out a contest report now? Of course it could also be operator error...
Fred
More likely programmer error hihi. Here is a fixed report. Unzip and put the resulting two files CONTEST.REP and CONTEST.FPT in the REPORT folder inside the LOGic install folder, replacing the two that are there. Tnx & 73, Dennis WN4AZY
LOGic Forum
LOGic Support
Contesting
