Attempt to print contest report SCORE_CONTEST error
WD4ASP
#1 Posted : Friday, September 16, 2016 8:36:00 PM(UTC)
I was testing out the 9.1.2 version and encountered the following error when attempting to print a contest report:
RunPRG: AN error occured in
Error#: 1773
Message:Class definition SCORE_CONTEST is not found.
Line#: in (memory variable): 19
Code:
Alias: LOG
I got this same error for the two contests I tried to print; ARRL 10 METER and the va qso party (in & out of state).
Is there something different that needs to be done to print out a contest report now? Of course it could also be operator error...
Fred
WN4AZY on 9/20/2016(UTC)
#2 Posted : Tuesday, September 20, 2016 8:55:15 PM(UTC)
More likely programmer error hihi.
Here is a fixed report. Unzip and put the resulting two files CONTEST.REP and CONTEST.FPT in the REPORT folder inside the LOGic install folder, replacing the two that are there.
contest.zip (9kb) downloaded 134 time(s).
