LOGic Forum
LOGic Support
Import and Export
Export ADIF convert LSB doesn't work
Posts: 16 Location: FL
Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
Export ADIF using: Convert to ADIF mode (USB & LSB to SSBm etc.) only converts USB (all LSB remain).
Mike Collins
1 user thanked kf4bq for this useful post.
Groups: Administrators, Beta Testers Posts: 3,257  Location: Auburn, GA Thanks: 1135 times Was thanked: 554 time(s) in 464 post(s)
Go to tools/setup/modes. Navigate to the LSB ACTUAL MODE record. Make sure the ADIF MODE is set to SSB. I'll check my master copy.
[quote=WN4AZY;6092]Go to tools/setup/modes. Navigate to the LSB ACTUAL MODE record. Make sure the ADIF MODE is set to SSB. I'll check my master copy.
That was it Dennis... The ADIF Mode for LSB was blank.
Mike
LOGic Forum
LOGic Support
Import and Export
